finally got internets!
6 Oct 2004
England
Woo finally got my internet installed today on base, as im 4km++ from the exchange i was told to expect speeds of around 0.5mbps :(
HOWEVER, just did a speed test and it came as 1.5mbps :)
I know there is a 10day testing persiod of the line, but i wondered is this speed likely to keep up?
How do i change the home hub from wep to wpa?
they usualy max out your line and then keep dropping the speed until they find a stable connection speed.
thanks, i have a problem with the security of the home hub
its on wep, so i want it on wpa as its more secure, however when i put it onto wpa, and put a custom password in, i just cannot connect to it, when i try connect it says enter the password etc and i do, but it just will not connect, this is after re-setting the hub.
