Hi, so as title says, i now have my crossfire set up.
I am running 2x5850's and i was hoping someone could run over these heaven results to make sure everythings ok?
Heaven Benchmark v2.5 Basic
FPS:57.8
Scores:1456
Min FPS:10.4
Max FPS:127.4
Hardware
Binary:Windows 32bit Visual C++ 1600 Release Mar 1 2011
Operating system:Windows 7 (build 7600) 64bit
CPU model:AMD Phenom(tm) II X4 965 Processor
CPU flags:4179MHz MMX+ 3DNow!+ SSE SSE2 SSE3 SSE4A HTT
GPU model:ATI Radeon HD 5800 Series 8.850.0.0 CrossFireX 1024Mb
Settings
Render:direct3d11
Mode:1400x1050 4xAA fullscreen
Shaders:high
Textures:high
Filter:trilinear
Anisotropy:8x
Occlusion:enabled
Refraction:enabled
Volumetric:enabled
Tessellation:normal
Highest temp during test was 72 on top card and 62 on bottom card.
Will the top card generally run hotter than the bottom one?
Bottom card is the Twin Frozr so will prob need a lesser fan speed so do you think it would be worth swapping them? Fan is incredibly loud on the top card
Cheers.
Also, can you make afterburner set different fan profiles for the different cards?
I am running 2x5850's and i was hoping someone could run over these heaven results to make sure everythings ok?Heaven Benchmark v2.5 Basic
FPS:57.8
Scores:1456
Min FPS:10.4
Max FPS:127.4
Hardware
Settings
Render:direct3d11
Shaders:high
Textures:high
Filter:trilinear
Anisotropy:8x
Occlusion:enabled
Refraction:enabled
Volumetric:enabled
Tessellation:normal
Cheers.
