Finally, how does this look.
Permabanned
29 Dec 2006
Finally, how does this look. Clocking to 3GHZ 24/7
After many things i have posted i think i have finally thought out what i am going to buy, thanks to you guys you have been very helpful, Thank You.
Cpu (Processor) - Intel Core 2 DUO E6300 "LGA775 Allendale £110.44 inc VAT - http://www.overclockers.co.uk/showproduct.php?prodid=CP-135-IN
Cpu Cooler + Heat sink - Arctic Cooling Freezer 7 £16.44 inc VAT http://www.overclockers.co.uk/showproduct.php?prodid=HS-017-AR
Motherboard - Asus P5B Deluxe (Socket 775) £123.36 inc VAT - http://www.overclockers.co.uk/showproduct.php?prodid=MB-150-AS
Memory (RAM) - Corsair 2GB DDR2 XMS2 £211.49 inc VAT - http://www.overclockers.co.uk/showproduct.php?prodid=MY-124-CS
Graphics Card - Sapphire ATI Radeon X1950 Pro £126.89 inc VAT http://www.overclockers.co.uk/showproduct.php?prodid=GX-134-SP
Hard Drive - Seagate Barracuda 7200.10 320GB £66.96 inc VAT - http://www.overclockers.co.uk/showproduct.php?prodid=HD-078-SE
Case - Thermaltake VA3000BWA Tsunami Dream £75.19 inc VAT http://www.overclockers.co.uk/showproduct.php?prodid=CA-010-TT
Power Supply - Corsair HX 520W ATX2.2 Modular £70.49 inc VAT http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-CS
Total : £802.37 inc VAT and inc Delivery
What would you change now that i have changed a few things, does it look all in sync with each other like one part isn't amazingly good for another if it is could you please point it out.
This machine will be for Gaming, Video Encoding, Watching DVDs etc.
ALSO with this Setup and the CPU E6300 is it being realistic saying could i run this at 3GHZ 24/7? or is that a bit to much to ask from that CPU?
Thanks again.
stickroad said:
I cant seem to find an OEM version in the overclockers shop or dont they sell one only the Retail Version?
In that case take Mr. Wolvotim's advice. :)
EDIT: Oh no! It is out of stock. :o
whatever you get, I would definitely recommend getting the aftermarket cooler. It's far quieter and it will do a superior job.
Oh good good, now you guys just gave me another choice now should i get the E6300 or the E6400 lol
Is their any other differences between the two apart from the Stock speed. to start of with?
They are both identical apart from their stock speeds, they both have the same amount of cache :)
