Great temps for air!
Good work.
1.25V is the same as my new 3570K.
Which is a 1.170V VID.
My old 3570K was a 1.190V VID and needed 1.28V for 4.5GHz.
You can manually tweak it, I disable overvoltage, and set LLC to turbo with offset of 0.
It depends on each chip though, some won't idle well with low voltage, my old chip needd +0.090V offset so I had to lower my Vcore LLC to Low to compensate.
You could maybe try my settings?
But we do have different boards.
Vcore LLC Turbo
DRAM LLC Extreme (to keep the voltage constant)
VTT Standard (1.050V set) is 1.060V in windows.
PLL Voltage is 1.500V down from the stock 1.800V
Offset 0.000V (Try up to +0.030V but with this lower the LLC until you find the 1.25V at load) +120 seems quite high for a chip that can be stable at 1.25V.
Does ASUS have a tool to lower the LLC's in windows? I play around with mine using Gigabyte's 3DPower tool.
My ram is just set to be stable at 2133MHz.
Nothing wrong with your settings, just the 1.30V spike in hardware monitor would make me want to fine tune it, to get a constant 1.25V like I have now. Mine is minimum 0.86V max 1.25V.
Brian, My ASUS P8Z77-V LX limits me in BIOS to Alter the PLL Voltage it has 2 settings, Auto and +0.010v and I cant figure out if theres another section on this board to change it, If I press the +/- keys to lower or raise it, it switches back and forth between Auto and the pre-configured 0.010v which makes me think, is this typical off this board, or is there another way to change the PLL Voltage? Also the minimum offset for this board is 0.005v 0.000 automatically sets at 0.005v
Also I ran it overnight, and for 5 hours today, and each time i get this on worker 2
[Oct 30 14:11] Test 13, 800000 Lucas-Lehmer iterations of M159745 using FFT length 10K.
[Oct 30 14:12] Test 14, 800000 Lucas-Lehmer iterations of M157695 using FFT length 10K.
[Oct 30 14:13] Test 15, 800000 Lucas-Lehmer iterations of M155649 using FFT length 10K.
[Oct 30 14:14] Test 16, 800000 Lucas-Lehmer iterations of M153599 using FFT length 10K.
[Oct 30 14:15] Test 17, 800000 Lucas-Lehmer iterations of M147455 using FFT length 10K.
[Oct 30 14:16] Test 18, 800000 Lucas-Lehmer iterations of M143361 using FFT length 10K.
[Oct 30 14:17] Self-test 10K passed!
[Oct 30 14:17] Test 1, 4500 Lucas-Lehmer iterations of M17432577 using FFT length 896K.
[Oct 30 14:18] Test 2, 4500 Lucas-Lehmer iterations of M17432575 using FFT length 896K.
[Oct 30 14:19] Test 3, 4500 Lucas-Lehmer iterations of M17115073 using FFT length 896K.
[Oct 30 14:20] Test 4, 4500 Lucas-Lehmer iterations of M16815071 using FFT length 896K.
[Oct 30 14:21] Test 5, 4500 Lucas-Lehmer iterations of M16515073 using FFT length 896K.
[Oct 30 14:23] Test 6, 4500 Lucas-Lehmer iterations of M16515071 using FFT length 896K.
[Oct 30 14:24] Test 7, 4500 Lucas-Lehmer iterations of M16297569 using FFT length 896K.
[Oct 30 14:25] Test 8, 4500 Lucas-Lehmer iterations of M15997567 using FFT length 896K.
[Oct 30 14:26] Test 9, 4500 Lucas-Lehmer iterations of M15597569 using FFT length 896K.
[Oct 30 14:27] Test 10, 4500 Lucas-Lehmer iterations of M15597567 using FFT length 896K.
[Oct 30 14:28] Test 11, 5300 Lucas-Lehmer iterations of M14942209 using FFT length 896K.
[Oct 30 14:30] Test 12, 5300 Lucas-Lehmer iterations of M14942207 using FFT length 896K.
[Oct 30 14:31] Test 13, 5300 Lucas-Lehmer iterations of M14155777 using FFT length 896K.
[Oct 30 14:32] Self-test 896K passed!
[Oct 30 14:32] Test 1, 5300 Lucas-Lehmer iterations of M14942209 using FFT length 768K.
[Oct 30 14:34] Test 2, 5300 Lucas-Lehmer iterations of M14942207 using FFT length 768K.
[Oct 30 14:35] Test 3, 5300 Lucas-Lehmer iterations of M14155777 using FFT length 768K.
[Oct 30 14:36] Test 4, 5300 Lucas-Lehmer iterations of M14155775 using FFT length 768K.
[Oct 30 14:37] Test 5, 5300 Lucas-Lehmer iterations of M13969343 using FFT length 768K.
[Oct 30 14:38] Test 6, 5300 Lucas-Lehmer iterations of M13669345 using FFT length 768K.
[Oct 30 14:39] Test 7, 5300 Lucas-Lehmer iterations of M13369345 using FFT length 768K.
[Oct 30 14:40] Test 8, 5300 Lucas-Lehmer iterations of M13369343 using FFT length 768K.
[Oct 30 14:41] Test 9, 5300 Lucas-Lehmer iterations of M13069345 using FFT length 768K.
[Oct 30 14:43] Test 10, 5300 Lucas-Lehmer iterations of M12969343 using FFT length 768K.
[Oct 30 14:44] Test 11, 6500 Lucas-Lehmer iterations of M12451841 using FFT length 768K.
[Oct 30 14:45] Test 12, 6500 Lucas-Lehmer iterations of M12451839 using FFT length 768K.
[Oct 30 14:46] Test 13, 6500 Lucas-Lehmer iterations of M12196481 using FFT length 768K.
[Oct 30 14:48] Self-test 768K passed!
[Oct 30 14:48] Test 1, 460000 Lucas-Lehmer iterations of M250519 using FFT length 12K.
[Oct 30 14:49] Test 2, 460000 Lucas-Lehmer iterations of M245759 using FFT length 12K.
[Oct 30 14:49] Test 3, 460000 Lucas-Lehmer iterations of M245281 using FFT length 12K.
[Oct 30 14:50] Test 4, 460000 Lucas-Lehmer iterations of M243713 using FFT length 12K.
[Oct 30 14:51] Test 5, 460000 Lucas-Lehmer iterations of M235519 using FFT length 12K.
[Oct 30 14:52] Test 6, 460000 Lucas-Lehmer iterations of M233473 using FFT length 12K.
[Oct 30 14:52] Test 7, 460000 Lucas-Lehmer iterations of M231183 using FFT length 12K.
[Oct 30 14:53] Test 8, 460000 Lucas-Lehmer iterations of M229375 using FFT length 12K.
[Oct 30 14:54] Test 9, 460000 Lucas-Lehmer iterations of M225281 using FFT length 12K.
[Oct 30 14:55] Test 10, 460000 Lucas-Lehmer iterations of M221183 using FFT length 12K.
[Oct 30 14:55] Test 11, 560000 Lucas-Lehmer iterations of M212991 using FFT length 12K.
[Oct 30 14:56] Test 12, 560000 Lucas-Lehmer iterations of M210415 using FFT length 12K.
[Oct 30 14:57] Test 13, 560000 Lucas-Lehmer iterations of M208897 using FFT length 12K.
[Oct 30 14:58] Test 14, 560000 Lucas-Lehmer iterations of M204799 using FFT length 12K.
[Oct 30 14:59] Test 15, 560000 Lucas-Lehmer iterations of M200705 using FFT length 12K.
[Oct 30 15:00] Test 16, 560000 Lucas-Lehmer iterations of M196607 using FFT length 12K.
[Oct 30 15:01] Test 17, 560000 Lucas-Lehmer iterations of M194561 using FFT length 12K.
[Oct 30 15:02] Test 18, 560000 Lucas-Lehmer iterations of M188415 using FFT length 12K.
[Oct 30 15:03] Test 19, 560000 Lucas-Lehmer iterations of M186369 using FFT length 12K.
[Oct 30 15:04] Self-test 12K passed!
[Oct 30 15:04] Test 1, 380000 Lucas-Lehmer iterations of M291913 using FFT length 14K.
[Oct 30 15:05] Test 2, 380000 Lucas-Lehmer iterations of M286719 using FFT length 14K.
[Oct 30 15:05] Test 3, 380000 Lucas-Lehmer iterations of M282625 using FFT length 14K.
[Oct 30 15:06] Test 4, 380000 Lucas-Lehmer iterations of M280335 using FFT length 14K.
[Oct 30 15:07] Test 5, 380000 Lucas-Lehmer iterations of M278527 using FFT length 14K.
[Oct 30 15:08] Test 6, 380000 Lucas-Lehmer iterations of M274335 using FFT length 14K.
[Oct 30 15:08] Test 7, 380000 Lucas-Lehmer iterations of M270335 using FFT length 14K.
[Oct 30 15:09] Test 8, 380000 Lucas-Lehmer iterations of M266241 using FFT length 14K.
[Oct 30 15:10] Test 9, 380000 Lucas-Lehmer iterations of M262143 using FFT length 14K.
[Oct 30 15:11] Test 10, 380000 Lucas-Lehmer iterations of M260335 using FFT length 14K.
[Oct 30 15:11] Test 11, 460000 Lucas-Lehmer iterations of M250519 using FFT length 14K.
[Oct 30 15:12] Test 12, 460000 Lucas-Lehmer iterations of M245759 using FFT length 14K.
[Oct 30 15:13] Test 13, 460000 Lucas-Lehmer iterations of M245281 using FFT length 14K.
[Oct 30 15:14] Test 14, 460000 Lucas-Lehmer iterations of M243713 using FFT length 14K.
[Oct 30 15:15] Test 15, 460000 Lucas-Lehmer iterations of M235519 using FFT length 14K.
[Oct 30 15:16] Test 16, 460000 Lucas-Lehmer iterations of M233473 using FFT length 14K.
[Oct 30 15:17] Test 17, 460000 Lucas-Lehmer iterations of M231183 using FFT length 14K.
[Oct 30 15:18] Test 18, 460000 Lucas-Lehmer iterations of M229375 using FFT length 14K.
[Oct 30 15:18] Test 19, 460000 Lucas-Lehmer iterations of M225281 using FFT length 14K.
[Oct 30 15:20] Self-test 14K passed!
[Oct 30 15:20] Test 1, 6500 Lucas-Lehmer iterations of M12451841 using FFT length 640K.
[Oct 30 15:21] Test 2, 6500 Lucas-Lehmer iterations of M12451839 using FFT length 640K.
[Oct 30 15:22] Test 3, 6500 Lucas-Lehmer iterations of M12196481 using FFT length 640K.
[Oct 30 15:23] Test 4, 6500 Lucas-Lehmer iterations of M11796481 using FFT length 640K.
[Oct 30 15:24] Test 5, 6500 Lucas-Lehmer iterations of M11796479 using FFT length 640K.
[Oct 30 15:25] Test 6, 6500 Lucas-Lehmer iterations of M11596479 using FFT length 640K.
[Oct 30 15:26] Test 7, 6500 Lucas-Lehmer iterations of M11285761 using FFT length 640K.
[Oct 30 15:28] Test 8, 6500 Lucas-Lehmer iterations of M10885759 using FFT length 640K.
[Oct 30 15:29] Test 9, 6500 Lucas-Lehmer iterations of M10485761 using FFT length 640K.
[Oct 30 15:30] Test 10, 6500 Lucas-Lehmer iterations of M10485759 using FFT length 640K.
[Oct 30 15:31] Test 11, 7800 Lucas-Lehmer iterations of M9961473 using FFT length 640K.
[Oct 30 15:33] Test 12, 7800 Lucas-Lehmer iterations of M9961471 using FFT length 640K.
[Oct 30 15:34] Test 13, 7800 Lucas-Lehmer iterations of M9837183 using FFT length 640K.
[Oct 30 15:35] Self-test 640K passed!
[Oct 30 15:35] Test 1, 7800 Lucas-Lehmer iterations of M9961473 using FFT length 512K.
[Oct 30 15:37] Test 2, 7800 Lucas-Lehmer iterations of M9961471 using FFT length 512K.
[Oct 30 15:37] Test 3, 7800 Lucas-Lehmer iterations of M9837183 using FFT length 512K.
[Oct 30 15:39] Test 4, 7800 Lucas-Lehmer iterations of M9737185 using FFT length 512K.
[Oct 30 15:39] Test 5, 7800 Lucas-Lehmer iterations of M9537183 using FFT length 512K.
[Oct 30 15:41] Test 6, 7800 Lucas-Lehmer iterations of M9437185 using FFT length 512K.
[Oct 30 15:41] FATAL ERROR: Rounding was 0.5, expected less than 0.4
[Oct 30 15:41] Hardware failure detected, consult stress.txt file.
[Oct 30 15:41] Torture Test completed 136 tests in 2 hours, 11 minutes - 1 errors, 0 warnings.
[Oct 30 15:41] Worker stopped.
This has started happening whatever OC I set
