Finally looking to upgrade from a Q6600, need some advice
11 Jan 2011
Somewhere
Afternoon :)
I'm thinking it's about time I upgraded from my q6600, which is obviously gonna require a complete overhaul of almost my entire rig. It's been years since my last proper upgrade so I'm pretty clueless about the best hardware to use at the minute.
I bought a gtx 570 about 2 years back and think its always been bottlenecked really... I paid £280 and they look to be selling for less than half of that second-hand. I was looking to SLI eventually on my new board, but don't know if I'd be better off selling the 570 and investing in a better card instead, whilst saving money on a cheaper mobo?
The other thing I'm unsure about is CPU performance. Are they at a point where overlocking is pretty pointless? I'm eying up the £150 Haswell CPU but noticed the previous generations are often still more expensive.
My budget for a CPU, mobo, RAM and SSD is about £400, I might be able to stretch further if a GPU replacement makes sense. If I was to replace my GPU though, I'd like to make the move to a mini-ITX gaming rig if possible.
Just looking to throw some ideas around and find out what might be the best way to go from peeps who are more in the know than me
570 is still a nice card.
id upgrade the haswell i5 you mentioned, then see how your gpu is performing.
i wouldnt throw money at a new gpu until you know you need a new one.
That was my initial thought, but I'd run the risk of either wasting money on an SLI board, or getting a single slot mini-ITX board when SLI was the better way to go
The GTX 570 is still ok, especially for older games, but its limited memory (1.2GB) and high power use makes SLI a bad choice. You'd be better off with a single 7950, or similar, if you want extra GPU performance.
Cheers, I'd forgotten the 570s are quite power-hungry. I won't be looking to upgrade the GPU immediately anyways but sounds like my mini-ITX build is a go :)
What's the general opinion on upgrade timing with the new x86 consoles coming out soon? Should I be expecting prices to take any noticeable drop in the near future?
