Well, I've always been a CRT whore, doggedly refusing to switch to LCDs.
I use an LCD at work, and it's very nice for desktop stuff, but I always wanted the high framerates that come from running at 100 or 120hz refresh rates, without Vsync, when gaming. I've noticed that tearing is far more noticable on CRTs, as the refresh rate can't generall be set higher than 60 or 75hz. This said, the tearing is less noticable than a CRT set at equivalent refresh rates (60 or 75hz).
Anyway - enough about CRTs. My 22" CRT has finally started to die, so it's panel time. I'm something of a noob here, and I'm not looking to be spoon-fed a model to buy, rather I'm wondering what the defining features are in the LCD market?
A few that I understand:
* Contrast ratio and brightness (fairly self explanatory)
* 1:1 pixel mapping: Would be a useful feature, but not essential for my needs.
* HDCP support / input types (again seems fairly self explanatory)
What I'm mainly interested in is the effect of response time. A lot of monitors quote 6ms, which to my mind should allow a refresh rate of ~166Hz, right? Obviously this is not the case, so what does the refresh rate indicate, in terms of picture quality for gaming? How about tearing? I've noticed some LCDs will happily run at 75Hz (and a few at 85Hz, which really helps with tearing) - what spec indicates that this will be possible?
Also, what about the 'advanced features' offered by some manufacturers, like the PIP (Picture-in-Picture) and PBP (Picture-By-Picture) quoted on the Dell 24"? Are these mainly marketing jibe, or are there real benefits to them?
Finally - where would you recommend for thorough, trustworthy monitor reviews?
Thanks in advance for any help
I'll probably end up going for a 24" monitor, at a price-point which satisfies my needs (no specific budget). If anyone thinks there is a strikingly good value / quality monitor at this size then also chime in and I'll look into it. Thanks again.
