As per the title, looking to build a new system after my i5 2500k system finally gave up the ghost. As you can tell, I value longevity.
Therefore I'm wanting to build an AM5 system, primary usage is gaming (currently at 2560x1080, but will probably move to 3440x1440 shortly - also potential to connect it to the 4k tv at some point for sofa gaming), and will have some light productivity work - so I'm thinking 7700x/non-x. Although the 7900 can be picked up around the same price as the 7700x in some places - would this be a better option?
I need the other following components speccing:
• motherboard - B650 or X670? The price difference between even B650 boards is crazy, what makes the expensive ones so much better?
• m2 ssd >=2tb (already have 2x sata ssds to connect to the mobo aswell)
• 32GB DDR5 ram
• AIO cpu cooler
I already have a case (NZXT H440) that I'm probably going to keep, and a newish EVGA 750W psu, and GPU which will be upgraded once AMD release the lower end new cards.
I guess for budget, somewhere under £1200 would be ideal. Happy to listen to suggestions for increase if its genuinely worth it. I'm not interested in chasing 1% differences as I'm only a casual gamer.
Thanks!
• 32GB DDR5 ram
• AIO cpu cooler
Thanks!
