Intel convert and spec'ing for a mid range gaming rig, to replace my aging AMD rig. I have already got;
Coolermaster HAF 912+
Asrock Z77 Extreme 4 mobo
16gb Samsung Green Ram
NZXT Sentry2 fan control
Additional 200mm Coolermaster and 140mm Bitfenix red led fans
I'm not an extreme OC fanatic, but would like to try and push over 4ghz (air)and keep the noise down
therefore I have avoided IB cos of heat (I won't saturate PCIe3 either) so that allows me to go i5 2500k and less agressive cooling and max out my £360 budget on the biggest SSD I can afford - about to pull the trigger on;
Core i5 2500k retail
Zalman CNPS9900-MAX Red Ultra Aero
SanDisk 240GB Extreme SSD
With £500 left for the front end of the system next month with;
Sapphire HD7870 OC (which will OC further) edit - loving the OC 7850 thread...
Dell u2412m 1920x1200 16:10 IPS
...final amendment (IF my overtime over the Olympics pays off) reason I went for the Dell IPS monitor was - I might end up with two more in eyefinity and want the IPS viewing angle to allow PPP of LLL trials with a second 78** CF. If I don't spend the extra on PC bits the rig should stand as it is, pretty well!
Any thoughts welcome
therefore I have avoided IB cos of heat (I won't saturate PCIe3 either) so that allows me to go i5 2500k and less agressive cooling and max out my £360 budget on the biggest SSD I can afford - about to pull the trigger on;Core i5 2500k retail
