Finally Seen the Light (Nero gone!!)
19 Oct 2002
Swindoniantown
I've finally seen the light and removed Nero 9 from my laptop (spec below in Sig!)!.. it was bloated, slow and buggy!...
Thing I'm annoyed with now is, how do I get rid of the crap its left behind!.. like the 'AutoRun' dialogue, it still shows (albeit without a propper icon) in the autorun when I connect a USB drive or insert a CD/DVD/Blu-Ray...
Anyone out there know how to remove these extra entries as they're bugging me! :mad:
Flippin Nero Crap!!!...
IMG Burn for burning images and reading etc and Ashampoo Burning Studio 6 (FREE) for everything else.
Job done :)
Yeah i agree, nero can be a bit bloated.
BUT, it's the only app I know that will burn .mp3's to a format my car cd can play. (I don't know what this format is, I just select the 'audio' option in nero express and it does the job). I can only fit about 10-15 tracks per 700mb disc though.
Yeah you're just burning an Audio CD which is the world's oldest consumer digital audio format perhaps :p
Ashampoo will do it as will many other apps as mentioned, heck even media player will burn an audio cd!
Ahh never realised that. I think with the other apps apart from Nero, when I tried burning some mp3's I must have selected 'keep original format' or something.
Might move over completely to one of the suggested apps.
Thanks
Personally I dont mind Nero
I think v6 is the best but with Win7, I have no choice but to use v8
Wouldnt piddle of v7 of course.
When I install it though, I simply chose to only have the basic Nero burner, the Cover editor ( to print DVD Covers ) and the Wave Editor ... Everything else is junk and bloat that I dont want and just these provide me with everythign I need.
another +1 for infrarecorder, went across to it from nero about a year ago never looked back.
Cheers Guys I'm using ImgBurn...
But anyone know how to remove the Nero Crap from my 'Autorun' dialogue.
Sim :)
Try CCleaner perhaps?
It's good to see an x64 edition of Infrarecorder, installed and replaced Ashampoo Burning Studio free :P
Yup, I don't mind it not having BluRay disc burning support just yet as it's going to be a while before I need to burn BD data discs with the size of USB sticks these days :p
So now my complete burning and ripping/encoding software consists of:
Mostly free too!
Shame that the newer versions of Ashampoo have followed Nero's trend of getting bloated - Version 6 FREE edition is still great but it's features have not been updated inline with version 9.x.
Nero is fine if you do a custom install and just put on the basics, but yes it is very bloated on a full / standard install.
I used to mess around with nero lite, tbh, I'd much rather just use something without any crap to begin with :)
