After much pain and agro of getting the XT to work correctly.. here at the results so far:
3DMark06
C2D E4300 @2.4Ghz, X1950XT@ 621/900, X4 PCI-E 101Mhz > 5492
C2D E4300 @2.6Ghz, X1950XT@ 675/999, X4 PCI-E 101Mhz > TBC
3DMark05
C2D E4300 @2.4Ghz, X1950XT@ 621/900, X4 PCI-E 101Mhz > 10022
C2D E4300 @2.6Ghz, X1950XT@ 675/999, X4 PCI-E 101Mhz > Artifacted after a while.
My thoughts are.. bit low on the scores, but it is running off a X4 PCI-Express slot thanks to ASRock and not the X16 normally expected.
Will try higher and lower voltages for the overclocked versions... just tired as 01:55AM right now
Matthew
3DMark06
3DMark05
Matthew
When I manage to get some ddr2 and a better motherboard I will finally be able to get the best out of both the CPU and the GPU
