The below is a finance calculation that I am having trouble solving. Say you have a set of nominal cashflows, a perpetual growth rate and a net present value. How would you solve for the implied discount rate? (clearly there won't always be a solution)
So in an example where you know the NPV is 10 and you have 5 years of cashflows of 1 and a terminal value calculated using a perpetual growth rate of 2%.
Note that the Terminal value is calculated as final cashflow * (1+growth rate) / (discount rate - growth rate)*(1+discount rate)^-5
I need a solution that I can implement in excel so it can be iterative. Any ideas?
Thanks for any help!
edit: in this example the cashflows are the same but it would need to be generalised so this isn't required.
