Getting a used 3070 is a bad idea. If you go Nvidia, you do it for the features, but a 3070 chokes itself due to low vram, so no point in buying one over an AMD card, used or not. Not to mention he said he has a 4K screen, so you want enough vram to use higher textures (which you can do, because they cost little performance... but a lot of memory). The only reason to ever get a used 3070 is if you find someone damn near giving it away for free.Nicely priced?get a used 3070 for basically half that for almost identical performance
I see there's now a 7800 XT at £410. That's a decent alternative. Still debatable given the examples he mentions (f.ex. CP2077 RT + Minecraft RT) where even the 7800 XT with all its extra grunt still doesn't beat the 4060 Ti AND also has worse image quality given FSR vs DLSS, but it's certainly much faster in raster (tho also much higher power draw). The issue is that the 7800 XT is a 'win more' card, where you have higher fps in situations where you're already >60 fps, but on the other hand the 4060 Ti has more options to get you to 60 fps (or a bit above) in situations where the 7800 XT would just falter and you'd have to enjoy the console cinematic 30-40 fps range.Was thinking the same, you need your head checking if you're working out nearly£400 for that.
7800xt new is ~400, that would be my pick
SAPPHIRE PULSE AMD Radeon™ RX 7800 XT Gaming Graphics Card with 16GB GDDR6, AMD RDNA™ 3 architecture
Order SAPPHIRE PULSE AMD Radeon™ RX 7800 XT Gaming Graphics Card with 16GB GDDR6, AMD RDNA™ 3 architecture now online and benefit from fast delivery.
