Find a string within a string
4 Jul 2004
aberdeen
Hello
I want to do the following:
Get the referrer
If the referrer includes "google" display $xxx
else display $yyy
How can i check if the referrer has a certain string (ie "google") in it?
All i've got so far is basically "$ref = getenv('HTTP_REFERER');"
(ps: this is in php)
stristr.
Code:
$str = 'foobar';
if ( stristr($str, 'foo') )
    echo 'string contains "foo"';
Or alternatively the slightly faster strpos, although it's case sensitive:
Code:
$str = 'foobar';
if ( strpos($str, 'foo') !== false )
Cheers :)
Another Q now:
I want to validate that $foo is in the format of "dd/mm/yy @ hh/mm".
How can i do a simple thing in the basic style of:
if (check($foo, "dd/mm/yy @ hh/mm") == true) {
echo "correct method";
else {
echo "sorry you must have entered it wrong etc";
(of course mm = numbernumber etc)
stripos also available from >=php5
or for php4 compat:
Code:
if (!function_exists('stripos'))
    function stripos($haystack, $needle, $offset = 0)
        return strpos(strtolower($haystack), $strtolower($needle), $offset);
Chronicle said:
Cheers :)
Another Q now:
Code:
else {
try:
Code:
if (preg_match('#^\d{2}/\d{2}/\d{2} @ \d{2}/\d{2}$#is', $string))
    echo 'Date format ok!';
