hi,
I have a big list of strings seperated by new lines. They all contain similar information - in fact they are all URLs. My task is to go through each line and add in a bit of extra information based on the URL. For example:
http://www.somesitehere.com/mysite/myfolder
http://www.somesitehere.com/hissite/hisfolder
http://www.somesitehere.com/mysite/myfolder2
http://www.somesitehere.com/mysite/myfolder4
http://www.othersitethere.com/hersite/herfolder
All I need to do is parse the string, check for example it says '/mysite/' somewhere in the string, and then add in:
'http://www.somesitehere.com/mysite/myfolder|client'
I could do this using If statements I'm sure, but the problem is that I have a lot of different strings to replace |client and a lot of URLs to sort.
Can anyone come up with a solution where I dont end up with a massive nest of If else's? Possibly using arrays...
If it helps I am using php 4, and havent slept for close to 25 hours now so I may be overlooking something very obvious.
Thanks for your time
