Find me a case :)
29 Aug 2010
United Kingdom
Hello forum :),
Basically I need your help to find me a case, I have searched for a while now and its really bugging me as I've pretty much turned up empty, which makes me sad :(
I am looking for a nice case that can house my current components (in sig) and be fairly small and compact compared to my huuuge NZXT Phantom. It needs to fit my H100 which knocks quite a few out of contention and I'd like it to have pretty good airflow,
price range is sort of up to about £100, can't see why it would cost more than that or even at that point as this full tower cost me £100+
Any advice or input would be greatly appreciated :)
Thanks,
Rb
Any of the corsairs (the 300R might not fit a H100, can't quite remember, but pretty sure the rest can)
Good solid cases as well.
CM690ii
I think the R3 would, but can't quite remember, nor can I remember about the R4, but both would be good options
Fractal Arc Midi is another good bet
Just pulled this off of another forum.
Will no doubt prove useful:
H100
COOLER MASTER
CM690 Std
Fits in base if HDD cage is partially removed, be careful that water pipes are long enough to reach CPU over graphics card.
Will not fit rear
CM690 II Advanced
Fits in base - Requires removing some of HDD cage - LINK & LINK(Shroud)
Fits in top as P/P using top fan mounts without issue, but is HW dependant. - LINK
Fits on top of case in P/P with some heavy modding - LINK
Fits in bottom in P/P + Some shrouds with some modding - LINK
Centurion 590
Fit in top in Push or Pull - Heavy modding required for P/P - Ext link
600t
Fits top but require modding for P/P configuration LINK
HAF 912
Fits top with some modding for P/P - see link - read full thread comments.
HAF X
Fits top without modding
Some modding may be required for P/P, may fit some cases without modding, HW dependant. - LINK
HAF 922
Fits top in Push or Pull, P/P not yet confirmed - links
HAF 932
Fits Push or Pull - LINK
P/P Confirmed - LINK
P/P confirmed, top 230mm may need to be removed if complete P/P configuration will not fit inside with hardware, check first.
Storm Sniper
P/P Confirmed with one on top, waiting on confirmation of 2 fans fiting - LINK
Storm Scout
Fits with modding for all configs - LINK
SILVERSTONE
Raven 02
Will fit P/P if case fans removed but not required, P/P possible using case fans - LINK
Raven RV-03
Fits in 5.25 drive bays with modding - LINK
TJ07
Fits in top with some very light modding and a few caveats, see -LINK
TJ10
Fits in P/P without issue - LINK
CORSAIR - Should fit all, but check first, waiting for links to individual case installs
400r
Fits in Push or Pull only - Modding required for P/P setup - LINK
500r
Another Push Pull setup - LINK
New info, fits P/P without modding but is hardware dependant, more specifically size of heatsinks - AWAITING LINK
600t SE
Fits Push or Pull confirmed - LINK & LINK
Push Pull - LINK & LINK
550D
Fits in the top in push or pull, P/P may be hardware dependant - LINK
650D
Fits in Push/Pull, be cautious about other components - LINK & NEW LINK
800D
Fits in top - Ext Link (Full Intsall) & Ext Link (Full Install) & LINK
NZXT
Phantom
Fits Push or Pull - Link & LINK
Fits in Push Pull with some modingd - LINK
TEMPEST 410
Fits in the top - EXT LINK
Phantom 410
Fits seperating the fan and rad either side of plate - LINK & LINK & Alt LINK
Gamma
Fits top with modding - LINK
Fits in Push/Pull without mods - LINK
ANTEC
300
Will fit in front with some quite heavy modding - LINK
Can be fitted in 3.5" bays with some modding - LINK - Thanks pale
1200
Will fit on rear in P/P - LINK & LINK & EXT LINK
900
Will fit in the front without modding at the loss of some bays - LINK
Dark Fleet (DF) 85
Yes, with mods - LINK
Push Pull without modes confirmed - LINK
Lanbot Air
Fits in front, full install guide - LINK
Thermaltake
Level 10 GT
Fits Push Pull - EXT YOUTUBE LINK & LINK
Fits Push or Pull, also shows space available for P/P config which may be HW dependant - LINK
RX-1
Fits in top in Push/Pull - LINK
Fits in the top IN P/P without removing 200mm fans but may be HW dependant due to space limitations around larger RAM or heatsinks. See LINK
V4
Fits in Push or Pull - LINK
Armor Plus
Fits in Push Pull custom fit - see link
Fractal Design
Arc Midi
Fits in top in Push or Pull
P/P now confirmed without modding - LINK - and alternative - LINK & LINK & LINK
Mini
Can be mounted in front - LINK
Arc Mini
Fits in top in push pull (lower profile rear 120mm fan required i.e. 25mm+ will not fit)- LINK
LIAN Li
PC 50
Can be mounted in the front in P/P with some heavy modding - LINK - UPDATED LINK
PC-V2120
Fits in Push/Pull - may be component dependant see - LINK
PC-K62
Fits with some modding, see - LINK
Rosewill
Thor
Fits in top in Push/Pull with some modiing. Modding should not be required for Push or Pull, but not yet confirmed - LINK
kd
Yeah I've seen that list, I do like the fractal design cases, I wish the Silverstone FT02 was cheaper or the Raven 2, Or if the RV-03 would fit the H100 somewhere else, As I need the 5.25 inch bay,
Arrrgh why is it so hard choosing a case! :p
Ok I just got tired of trying to find something small, It will have to fit somewhere I guess, I went with the Switch 810 as I got a good deal at around £120 with the Lamptron touch white fan controller as well.
Thanks for all the help though guys :)
If you can hold out and push for a Corsair 650D, they range from £120-£150 depending on where you get. ** No competitor naming and pricing ***
It really is a nice big, sleek and stylish case. I love it to the point this will last me 5 years, maybe more unless advances in technology requires me to get a new one. Or if I come into a bit of money, go for a full towered case with water cooling, etc.
A Midi tower at that price? No thanks.. Too small for me, As I said I picked up a Switch 810 which is a full tower for £120 and a fan controller, And It is amazing.
