Hi guys
I'm nearing the end of my new build and as such I'll be selling off my old system parts, one thing I have in mind is to use the funds to replace my old LG 1440x900 screen...
So find me a monitor!
Specs I require:
I play FPS so 100htz+ is a must, not sure if 144htz is worth the extra expense?! (TN / S-IPS?)
Going from 1440x900 I don't think 1080p is a sensible step as I tend to keep my screens 10+ years, so next up is 1440p (want to avoid any limitations with 1200p).
Response time will be low for anything around the 100htz+ range.
Physical size doesn't bother me too much, ideally if I can find a 21"/22" with 2560x1440 I'd be very happy as in theory the smaller screen size will make it cheaper, I'm using an older Hanns G 21" HZ221 (1680x1050) at work and the physical size is about right!
Ideally I'm looking to spend ~£200 (yes I know I'm a cheapskate!
Specs I require:
