- 9 Jan 2008
- UK
Hi all...
Been trying to find a replacement dual-flush plate for our fancy toilet! Most of the unit is hidden behind the wall and its just the bowl and flush-plate that can be accessed.
Basically the flush-plate clips that hold the actual flushing buttons on have snapped and we just cannot find any information on the one we have.
Also we have tried to order a replacement online going only on it being exactly the same dimensions, the same make and looking sorta the same. However this came through the post and the it only needs one "air pipe" (no idea what they are called) and we have two "air pipes" currently. One for each flush button.
Silly me assumed all dual flush systems would work with a pipe for each flush.
So two things really...firstly...if I give out the only number that is written on our original flush plate....can someone identify what it actually is and whether we can get another. GROHE 93.138.031/AM 208978/10.06
Secondly, seeing as the first option is probably not likely, can anyone tell me if there is a specific term I should be remembering for a dual flush system with two pipes? The one we bought was a GD2 system or something like that?
Many thanks
Many thanks
