Finding an IP address
Don
23 Oct 2005
North Yorkshire
Hi guys,
I have a networked hard drive thats on my network that I can access its folders but i cant web browse onto as I have no idea what IP address it has, is there an application out there I can run and it displays such info? My router doesnt display wired items
Cheers
copy a file from it then run netstat -a from a command prompt. Look through the foreign addresses.
That or get an IP scanner and scan your subnet.
Could have a look on the MAC address table of whatever switch it's attached to get the MAC to perform the above.
Do the shares not display \\[Hostname] to get you the hostname?
Otherwise, as above, netstat or IP scanner on your subnet. (Unless you're using a Class A which will take an age [10.x.x.x]).
