Finding CD key from regedit (photoshop)
26 May 2006
Edinburgh
I have lost the cd-key for my copy of photoshop element 7.0, is there anywhere in the registry that will show me what cd-key was input?
Belarc might provide you with the info, I know it does with the OS and any Office versions you have
Might be worth a shot :)
I don't have photoshop, so can't tell you where it is exactly in the registry, but they're generally kept in:
HKEY_CURRENT_USER\Software\Whoevermakesit(Adobe?)\Photoshop
Something like that anyways :).
Ah :(
Apparently only older versions of adobe kept the key in the registry, so you might be out of luck here. As others said, give belarc a try : http://graphicssoft.about.com/gi/o....1&zu=http://www.belarc.com/free_download.html
It doesn't show keys for all Adobe products, but it does for some/most, so may or may not work, probably most likely tho :).
I did actually find the key in the registry but the last 4 digits are removed, I guess this is done by photoshop as a security feature.
Belerac worked though, so thanks :]
