- 19 Oct 2008
The house had a issue back in 2015 and my heating guy managed to use leak sealer to seal the leak. It's back again. Has anyone tried using a company to detect leaks successfully? I've read recently about specialist companies using air or gas and using sound detection devices to listen for the leak. Wondering if anyone has used this and how successful was it?
The house is a relatively new build, a private one, and all the heating pipework (plastic) is in the walls/under tongue and groove floorboards. We've pretty sure it's on the ground floor as there's never been any damp patches spotted on the ground floor ceiling or any walls. Lifting(cutting out) the floorboards or parts of them which the room partititions are probably built on top of will be pretty painful and time consuming.
Anyone else tracked down a leak? How did you do it?
