Hello chaps,
Wondering if anyone can recommend some fine mesh filter for the intake on my PC cabinet. Just a roll / piece of mesh, don't need borders, magnets etc
I can't find anything I know will work well, and I can't afford to buy a few in the hopes one is suitable. Ideally:
OCUK sells a very limited range, so I don't believe links will break any forum rules. If you're unsure, feel free to PM me!
- CHEAP! Less than a fiver inc. ideally
- Decent filtration, not mega restrictive
- 46.5cm x 18.5cm minimum
- Any material; Plastic, fabric, metal etc
- White. Can live with bear metal
- Long lead times fine
