Finished my build!!!!
1 Jan 2012
Scottish Borders - UK
The completed project....
Very happy so far. Took a bit longer than expected and some faffing, but got there in the end!
Getting 61 Deg C at 4.6Ghz (i5 2500K) this is with mw just going into the UEFI and telling it to load settings for 4.6Ghz. This is with a voltage of 1.37.
If I knew how to overclock properly with adjusting the voltage instead of just changing the multiplyer, no doubt the temp would be lower.
This is also with me running two fans at 900rpm and two at 700rpm.
Thoughts??
Looks great. You did well to get it all in there with those thick rads. That D5 looks huge in there. Enjoy!!
Have you thought about a modular PSU?
It is a modular PSU! lol
I'll be changing out for something like a AX650 soon.
Yeah.. the D5 is huge in that case!! I didn't think I would fit it in to be fair!!
I did have a slight scare initially as the temps were hitting 70deg on the CPU under load @ stock settings!
I then noticed the pump wasn't plugged in properly!! Ha!
