Fire-strike overclock
3 Feb 2010
Behind you
Sorry i couldn't find the official fire-strike thread, and i know time-spy has mostly taken over in terms of benchmarks..
Is this a reasonable result with this overclock? I'm pretty unsure about overclocking right now, and trying to experiment in the safest way possible..
CPU is at 4.5ghz
GPU is at +70mhz with a 120% power limit 92 degree target and +450mhz memory clock
I seem to hit a bit of instability if i take the GPU clock any further, but it hits about 2033-2050mhz under load. the GPU doesn't hit 70 degrees in all tests ive done so far. The CPU maxed out at 69 degrees, but i do need to change the orientation of my radiator fans, for better cooling.
that looks like a decent score.
my zotac amp extreme did 22.887 ( GPU score ), although that was without any OC, but Zotac are known to push their cards and factory OC them, which I absolutely love :)
