Firebase api - website help.
12 Nov 2003
Hello,
Just wondering if there any firebase experts around or if anyone knows where I can find one.
I have a site (table with an input form, edit and delete row features) constructed using firebase, however, I am having major issues getting it running on IE8 which I need.
Hi,
Thanks for the reply.
The website works totally fine in modern browsers. It's just IE8 I am having serious problems.
It may be better if I show you and you may be able to spot something.
Do you have an email I can send you details?
Cheers bud.
Hi,
Cheers bud.
Just send me a message in trust. AFAIK firebase uses websockets and websockets aren't supported at all in < ie10, though I would've thought they'd have provided a shim or a fallback for it.
