Caporegime
- 8 Jul 2003
- In a house
As title, mines just updated.
Good for you.
As title, mines just updated.![]()
Fixed in Firefox 2.0.0.12
MFSA 2008-11 Web forgery overwrite with div overlay
MFSA 2008-10 URL token stealing via stylesheet redirect
MFSA 2008-09 Mishandling of locally-saved plain text files
MFSA 2008-08 File action dialog tampering
MFSA 2008-06 Web browsing history and forward navigation stealing
MFSA 2008-05 Directory traversal via chrome: URI
MFSA 2008-04 Stored password corruption
MFSA 2008-03 Privilege escalation, XSS, Remote Code Execution
MFSA 2008-02 Multiple file input focus stealing vulnerabilities
MFSA 2008-01 Crashes with evidence of memory corruption (rv:1.8.1.12)
I updated mine manually. Might as well not bother with the automatic update because Firefox says it has downloaded the partial update then when I restart it, it tells me it didn't work so it has to download the full install.![]()
Phew! Not just me. I couldn't work out why it was always me. Happens on my PC both here and at home so can't be the Uni network or home ISP.Does exactly the same on my laptop, must be a bug
Burnsy
I'm on v3.02b
It's not a Vista issue. The partial update didn't work on my laptop at work yesterday, but worked fine on my home desktop, both on XP SP2 (well, one MCE 2005). The only obvious difference was Fx had been up all morning on my laptop while it hadn't been open more than a couple of minutes on my desktop. Not that I care though. It's hardly taking much out of my day to download the full update, and if it works, it works.There should be an update log generated (C:\Program Files\Mozilla Firefox\updates\last-update.log), so you can work out why it isn't updating from there, but AFAIK there's no bug filed for partials not working (if it downloaded a partial in the first place, but that shouldn't be an issue with the 1.8.1 branch).
It just worked for me on Windows XP too, so I'm guessing it's an issue with Vista (some of the compatibility stuff won't make it through to 2.0.0.x) or something else.
extensions.checkCompatibility turned off).
