(not least there's loads of UI work to do)
You mean can Proto be installed on XP or will there be a separate theme brought in a la Proto?
If you mean the latter, no. The former, probably not.
No, it's not just youIs it just me or is this a speed demon compared to Fx 2?
One of the objectives of v3 of FF is to make it faster loading web pages, as well as more secure.Beta4 has a new UI so Aero effects should be in there![]()
which is good because FF needs a bit of seethruness...
I read that the window transparency effects similar to what IE7 has will be what is implemented in B4 - which is good because FF needs a bit of seethruness...
Still got the rubbish bookmark manager where you can't drag'n'drop anything...
Also now when you order bookmarks by Name it doesn't do it the old way of directories/folders first, then single bookmarks, it mixes them all together.
laces]-Cannot drag and drop folders / items in Places Organizer [All] RESOLVED FIXED
