I just upgraded to FF7 and it deleted my list of open tabs
Just in case this happened I made a backup of sessionstore.js but it seems the backup I made is corrupt as when I replace sessionstore.js with my backed up version if just disregards it and loads my homepage.
The file itself seems fine, it opens up in Notepad and is accessible. Is there anyway of decoding the sessionstore.js into a more readable format?
I know it should work because I tried an old backup from a few days ago and that gives my the option to restore the tabs if I load it.
edit: Nevermind, found a backup version from today thanks to System Restore!
.Just in case this happened I made a backup of sessionstore.js but it seems the backup I made is corrupt as when I replace sessionstore.js with my backed up version if just disregards it and loads my homepage.
