firefox alzheimers
29 Oct 2005
Hi guys,
just recently I have to login to view my gmail on my homepage, i have to login to digg and other websites even though they are set to remember me. they work in other browsers but firefox seems to have broken somewhere. I have deleted cookies, should I make a new profile - if so how do i do this?
thanks
daven
To make a new profile, close Firefox. Locate the shortcut to it, and add: -p after the path to the exe.
So it will read something like:
"C:Program Files\Mozilla Firefox\firefox.exe" -p
Then when you run it, you should be prompted to select profiles, etc..
Edit: Then just remove the '-p' afterwards to return the shortcut to normal.
If you're going to follow that route, you also need to check "Don't ask at startup".
Alternatively, if you give the profiles meaningful names, you can use -P [ProfileName] to start Firefox with the profile you want.
