Firefox and memory usage
Permabanned
24 Jul 2005
R'lyeh
Is anyone else experiencing major memory usage with the latest Firefox? At the moment, after 23 minutes and with two tabs open, it's using 105MB and is becoming very lethargic.
shine said:
Minimise it - firefox will release any memory it no longer needs.
Didnt work for me...
i have about 20 tabs open, and its consuming about 150 MB, and when i close some, and minimise and maximise, its still at 150MB.
But me, i dont reall care, i have enough memory to combat it, and im only opening firefox, so its not being use on somthing else.
What version are you using? In some of the 1.5.x branch there was a bug and it didn't work. It is fixed in all the 2.x versions.
Ahh... im still running 1.5.0.12
Oh well no worries, im used to it, so i dont mind.
There is an add on which will fix it, you can download it here - search for FireFox 1.5 Memory Optimiser.
Same here, I have 2GB of decent RAM, Mushkin, but it's just weird how Firefox takes up so much. Perhaps it might also be down to what Extensions/themes are installed too.
Gamewise, I can easily run Guild Wars and Firefox but other, more intensive, games don't seem to like it.
Still takes too much RAM in my opinion, even if it is a superb browser. Got it open at the moment with 2 tabs, one being OcUK and it's consuming 72MB of RAM, which is horrendous.
Craigius said:
Thanks will have a look at this one when i get home. :)
Don't bother the general consensus is it doesn't work unless you change another entry to false in which case it starts thrashing pages to the HD.
Worked fine for me
Really so is there a fix for this then or will i have to live with Firefox taking up a ram?
