Firefox being weird.
5 Sep 2005
Northern Ireland
On Overclockers and a few other forums when I click the buttons to insert smilies, or tags or whatever, nothing happens.
It works fine on my PC in Opera, and I seem to remember I fixed this problem before, but can't remember how. Does anyone know what the craic is?
Some kind of JavaScript blocker like NoScript installed? They work fine here (though I have no idea what version you're using).
Some badly written Greasmonkey scripts & FX extensions can do this as well, basically anything that meddles with the page source :)
Try disabling everything, and then re-enabling one by one; If there was a wider problem, far more peeps would be posting about it than just you :p
-Leezer-
