My understanding is that probedb isn't trying to install from a site but instead from the .xpi saved to disk? The way around this is to open up Firefox and the extension manager (Tools>Extensions) and then drag and drop the .xpi file into the extension manager from the folder on disk.AcidHell2 said:got a link to where you trying to download from?
null said:My understanding is that probedb isn't trying to install from a site but instead from the .xpi saved to disk? The way around this is to open up Firefox and the extension manager (Tools>Extensions) and then drag and drop the .xpi file into the extension manager from the folder on disk.Not sure why you would want to do this though, extensions are generally very small.
Hope this helps, null![]()
Weird, didn't work last time I tried thattolien said:Associate the xpi with Firefox and it will install when you double click it.
