A couple of things which should be eminently solvable but struggling with all the same:
1: Cannot change theme from default. Just upgraded to version 1.5 and firefox seems reluctant to let my choice of skin/theme stick.
>Tools>Themes
>select desired theme from popup (in this case Modern Pinball 1.5.1)
>click use theme (green tick button greys out)
>follow suggested instruction to shut down firefox so that new theme can take effect
then on relaunch it's back to the default. most puzzling. I know not all themes work with v1.5 but my selection does or should (it isnt greyed out as obsolete/incompatible)
2: Unable to permanently clear history and address bar autocomplete.
This is a longstanding problem, I have completely uninstalled Firefox in the past and then reinstalled to no avail. Quite at a loss. tried CCleaner and other 3rd party utilities. I can go to tools>clear private data and history & address bar list is cleared for the current session only. restarting Firefox will miraculously present all the data just cleared. Very very frustrating
Any help on these two issues much appreciated
Sols
>Tools>Themes
Sols
