Firefox help
Caporegime
20 Oct 2004
Hey
Sorry if i'm being stupid here, used to be able to right click and google search with firefox. Now its disapered and can't find any option to turn it back on! What am I doing wrong guys? :confused:
Hi,
The search option on the right click menu mirrors the search engine you have in the top left hand corner of the screen.
To search using google just select Google from the drop down list.
If this doesn't work you may have an extension installed that has changed it.
Hope this helps
Rich
