Firefox : Problems with forum
2 Aug 2004
Buckinghamshire
Using firefox 2.0.0.6, I can't seem to be able to click the quick reply button. Also can't seem to use the WYSIWYG editor buttons (bold, italic, list) in advanced reply mode. Also can't click smilies?
Anyone else experienced this? I'm going to try with the default profile now.
Hmm default profile seems to have sorted it. Must be an extension conflict. I'll update the thread if I find out which one incase someone stumbles onto the same error.
Could it not be your profile getting its knickers in a twist?
And awfully good of you to update the thread if you find out what extension it is.
Weird, after clearing my OcUK cookie by logging out then back in - it seemed to get fixed.
Happening again now, and nothing despite trying the same fix. Only have 4 extensions installed and disabling them and restarting Firefox doesn't seem to help.
Think I may need to reinstall FF :)
