furnace said:I'm not sure about that, but folders within folders are probably a better idea than taking up screen space with another toolbar..?
BillytheImpaler said:How about this?: http://forums.mozillazine.org/viewtopic.php?t=254701
EDIT: The way I keep my bookmarks is as favicons largely with no label. I can fit about a hundred of them across the screen. Just an idea.
Like so:
BillytheImpaler said:I just tried the method at the link to see if it would work:
This is Firefox 2.0.0.4 on Windows. What did it do when you tried it?
* Edit this file and copy it as userChrome.css into your
* profile-directory/chrome/
* This file can be used to customize the look of Mozilla's user interface
* You should consider using !important on rules which you want to
* override default settings.
* Do not remove the @namespace line -- it's required for correct functioning
@namespace url("http://www.mozilla.org/keymaster/gatekeeper/there.is.only.xul"); /* set default namespace to XUL */
* Some possible accessibility enhancements:
* Make all the default font sizes 20 pt:
* font-size: 20pt !important
* Make menu items in particular 15 pt instead of the default size:
* menupopup > * {
* font-size: 15pt !important
* Give the Location (URL) Bar a fixed-width font
* #urlbar {
* font-family: monospace !important;
* Eliminate the throbber and its annoying movement:
* #throbber-box {
* display: none !important;
* For more examples see [url]http://www.mozilla.org/unix/customizing.html[/url]
BillytheImpaler said:Copy your userChrome.css here and let's take a look at it.
* menupopup > * {
* #urlbar {
* #throbber-box {
* For more examples see http://www.mozilla.org/unix/customizing.html
/* Multi-row bookmarks toolbar */
#bookmarks-ptf {display:block !important;}
#bookmarks-ptf toolbarseparator {display:inline !important;}
BillytheImpaler said:The file in question is located at C:\Documents and Settings\your user name\Application Data\Mozilla\Firefox\Profiles\some random gibberish.default\chrome\userChrome.css, rght?
