megatron said:http://downloads.guru3d.com/download.php?det=1302
Link to CCC 6.1, but Im using 6.1 display driver + 6.3 control panel.
This has driver, cataylst crappola panel and WDM drivers. I assume u can find 6.3 DD + control panel from ATI site (under fireMV). Im using 6.1 DD, 6.3 CP and 6.4 WDM. Just install them separately. Extract the installer package and dont continue with installation. Then just take the display driver and keep it (same with control panel).locutus12 said:this is for the old CCC yes? not the new horrid crap that it is now?
) i want a direct link to a version of FIREMV that will work under cat driver 6.1 as the only FIREMV ones i can find all say they are for cat 6.3 and above.megatron said:If u want to use 6.1 display drivers, with a control panel; it doesnt matter what CP you use since it hasnt changed for quite a while. If u dont want that, then Ive mis-read. Its really irrelevant what card u are using the drivers with since its a unified driver architechture.
