- 13 Jan 2004
- Leicestershire
I have my Plasma TV mounted on the wall.
I can fit a fireplace below it as there's a hole in the wall with a gas pipe and a flu.
At the moment i have a piece of wood screwed to the wall and i'm doing ok with heat etc.
I want a fireplace and Aldi are doing an eectric one for £90.
http://www.aldi.co.uk/uk/html/offers/special_buys3_23137.htm
It'selectric so i have 2 questions.
1. could it be run from an existing plug socket (easy) or would it involve a brand new feed from the fusebox(difficult)?
2. Could i mount if to the wall below the Plasma? I was thinking fit a shelf under the TV to deflect the heat away and fit some radiator foil underneath to deflect the heat in front of the TV more. Does this soud sensible or over kill?
