Firestick Replacement - what to get though
14 Nov 2012
Close to Swindon, but not Swindon
I still have a Gen1 firestick and it's starting to really tick me off...actually it's been doing it for a while now. I've been looking at:
  • Firestick Gen3
  • Fire TV Cube
  • Sidiwen Android 9 TV box
I'm leaning towards the Fire TV Cube as my history of the firestick means it doesn't have much of a life span. Mine has lasted 3 years and it's going to get thrown out if it continues to play up.
So, is the Cube really worth it? Are there other options that I should consider?
Not a fan of Roku with a fire stick far more android apps can be installed.
Each to their own i suppose.
I really like the firestick design but the Gen1 was outdated very quickly. It struggles as you start installing multiple apps and I've had to hard reboot it more than once in order to get it too respond to commands.
Hopefully the Gen3 lasts longer.
If you want Atmos sound with netflix get the cube not the stick. The stick cannot do enhanced atmos sound via netflix. So I vote cube as it gives far better sound.
