Firestrike score halved after Boot problem?
14 Jul 2013
Hi Guys, I'll try to keep it brief;
I recently had a drama with Windows where it wouldn't boot properly. It would hang just before the login screen and display a 1mm thin rainbow across the top of the screen.
It happened after a windows update reboot and logging in via Safe Mode would show it hanging up on CLASSPNP.SYS. A carefully timed jab of the Enter key would get me into Windows and as I've been playing Elite (which you could render on a C64) I never noticed the massive drop in FPS. I DDU'd and reinstalled drivers etc to no avail, using onboard would also fail boot up.
So, after trying everything to sort the boot fault (I wont bore you with details unless you'd like?) I eventually admitted defeat and did a fresh install. Problem solved? No such luck lol
I now boot absolutely fine but the GPU issue remains.
Here is a pre-problem run http://www.3dmark.com/fs/3297250
And here is the run from earlier http://www.3dmark.com/fs/4000642
The GPU portions of the run are literally half of what they once were and I'm totally miffed as to why?
Any pointers would be appreciated before I go completely potato!
Everything looks good on the cpu side from the physics score. Try running 3dmark while running afterburner to monitor everything that's going on. It may point you in the correct direction. Run Gpu-z to see what is said about the pci-e speed.
check power cables for the GPU, maybe try re seating the GPU and try a memory test like prime 95 and see if that reports back any issues.
I've reseated the card and all power cables are in nice and tight. Prime 95 ran without problems and GPU-Z reports PCIe 3.0x16 @ x16 1.1 I just benched Heaven using Kaaps benchmark criteria and it ran 1713 which is a half decent score I guess?
I was getting weird halos around people and vehicles in Arma 3 a few weeks back too?
run the render test on GPU-z see if that goes to x16 3.0 if not that could indicate a problem, random but have you reseated your cooler recently? I had to undo mine slightly which brought the pcie lanes back to full speed
Aye, it bumps up to 3.0 under load. I haven't swapped out any hardware for ages so I think the card/cooler will be seated nice and snug even more so after today's double checking.
This all started after it done the windows update and the reboot. I wonder if the card didn't like a few solid hours of gaming then a reboot?
Here's the log file dump of GPU-Z whilst running the Firestrike Extreme benchmark
Date , GPU Core Clock [MHz] , GPU Memory Clock [MHz] , GPU Temperature [°C] , Fan Speed (%) [%] , Fan Speed (RPM) [RPM] , Memory Used [MB] , GPU Load [%] , Memory Controller Load [%] , Video Engine Load [%] , Bus Interface Load [%] , Power Consumption [% TDP] , PerfCap Reason [] , VDDC [V] ,
2015-02-06 19:34:10 , 324.0 , 162.0 , 25.0 , 31 , 1044 , 138 , 1 , 4 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:34:11 , 324.0 , 162.0 , 26.0 , 31 , 1044 , 138 , 0 , 4 , 0 , 0 , 6.2 , 16 , 0.8870 ,
2015-02-06 19:34:12 , 324.0 , 162.0 , 26.0 , 31 , 1045 , 138 , 1 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:34:13 , 324.0 , 162.0 , 25.0 , 31 , 1042 , 138 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:34:14 , 324.0 , 162.0 , 25.0 , 31 , 1042 , 138 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:34:15 , 324.0 , 162.0 , 25.0 , 31 , 977 , 138 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:34:16 , 324.0 , 162.0 , 26.0 , 31 , 1041 , 139 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:34:17 , 324.0 , 162.0 , 25.0 , 31 , 975 , 139 , 0 , 4 , 0 , 0 , 6.0 , 16 , 0.8870 ,
2015-02-06 19:34:18 , 1084.5 , 1800.0 , 26.0 , 31 , 1028 , 149 , 0 , 0 , 0 , 0 , 28.3 , 16 , 1.0500 ,
2015-02-06 19:34:19 , 1084.5 , 1800.0 , 27.0 , 31 , 1010 , 149 , 1 , 0 , 0 , 0 , 28.8 , 16 , 1.0500 ,
2015-02-06 19:34:20 , 1084.5 , 1800.0 , 27.0 , 31 , 950 , 149 , 1 , 0 , 0 , 0 , 28.9 , 16 , 1.0500 ,
2015-02-06 19:34:21 , 1084.5 , 1800.0 , 28.0 , 31 , 1014 , 149 , 1 , 0 , 0 , 0 , 28.9 , 16 , 1.0500 ,
2015-02-06 19:34:22 , 888.7 , 1749.6 , 27.0 , 31 , 954 , 186 , 0 , 0 , 0 , 0 , 27.6 , 16 , 0.9750 ,
2015-02-06 19:34:23 , 888.7 , 1749.6 , 28.0 , 31 , 1020 , 184 , 0 , 0 , 0 , 0 , 27.0 , 16 , 0.9750 ,
2015-02-06 19:34:24 , 1084.5 , 1800.0 , 28.0 , 31 , 1021 , 213 , 2 , 1 , 1 , 0 , 27.4 , 16 , 1.0500 ,
2015-02-06 19:34:25 , 1084.5 , 1800.0 , 28.0 , 31 , 958 , 195 , 3 , 0 , 8 , 0 , 29.0 , 16 , 1.0500 ,
2015-02-06 19:34:26 , 1084.5 , 1800.0 , 28.0 , 31 , 961 , 193 , 0 , 0 , 6 , 0 , 28.8 , 16 , 1.0500 ,
2015-02-06 19:34:27 , 1084.5 , 1800.0 , 28.0 , 31 , 1035 , 193 , 0 , 0 , 4 , 0 , 28.8 , 16 , 1.0500 ,
2015-02-06 19:34:28 , 1084.5 , 1800.0 , 29.0 , 31 , 1038 , 193 , 0 , 0 , 3 , 0 , 28.8 , 16 , 1.0500 ,
2015-02-06 19:34:29 , 1084.5 , 1800.0 , 29.0 , 31 , 1040 , 192 , 1 , 0 , 2 , 0 , 28.9 , 16 , 1.0500 ,
2015-02-06 19:34:30 , 888.7 , 1749.6 , 28.0 , 31 , 1040 , 192 , 1 , 0 , 2 , 0 , 27.3 , 16 , 0.9750 ,
2015-02-06 19:34:31 , 1084.5 , 1800.0 , 29.0 , 31 , 1038 , 192 , 2 , 0 , 1 , 1 , 29.0 , 16 , 1.0500 ,
2015-02-06 19:34:32 , 1084.5 , 1800.0 , 29.0 , 31 , 1037 , 192 , 1 , 0 , 1 , 0 , 29.0 , 16 , 1.0500 ,
2015-02-06 19:34:33 , 1084.5 , 1800.0 , 29.0 , 31 , 1036 , 192 , 0 , 0 , 1 , 0 , 28.8 , 16 , 1.0500 ,
2015-02-06 19:34:34 , 1084.5 , 1800.0 , 29.0 , 31 , 1035 , 228 , 2 , 2 , 1 , 0 , 29.3 , 16 , 1.0500 ,
2015-02-06 19:34:35 , 1084.5 , 1800.0 , 29.0 , 31 , 1034 , 228 , 1 , 2 , 1 , 0 , 29.3 , 16 , 1.0500 ,
2015-02-06 19:34:36 , 888.7 , 1749.6 , 29.0 , 31 , 1034 , 260 , 3 , 1 , 1 , 1 , 27.2 , 16 , 0.9750 ,
2015-02-06 19:34:37 , 888.7 , 1749.6 , 29.0 , 31 , 969 , 480 , 3 , 0 , 0 , 1 , 27.2 , 16 , 0.9750 ,
2015-02-06 19:34:38 , 888.7 , 1749.6 , 29.0 , 31 , 969 , 483 , 0 , 1 , 0 , 0 , 27.2 , 16 , 0.9750 ,
2015-02-06 19:34:39 , 666.4 , 405.0 , 29.0 , 31 , 983 , 514 , 4 , 4 , 1 , 2 , 12.2 , 16 , 0.9000 ,
2015-02-06 19:34:40 , 666.4 , 405.0 , 28.0 , 31 , 1053 , 572 , 1 , 3 , 1 , 1 , 12.1 , 16 , 0.9000 ,
2015-02-06 19:34:41 , 324.0 , 162.0 , 28.0 , 31 , 1054 , 580 , 1 , 7 , 1 , 0 , 12.1 , 16 , 0.8870 ,
2015-02-06 19:34:42 , 324.0 , 162.0 , 28.0 , 31 , 989 , 581 , 2 , 7 , 1 , 0 , 9.6 , 16 , 0.8870 ,
2015-02-06 19:34:43 , 324.0 , 162.0 , 28.0 , 31 , 988 , 581 , 0 , 6 , 1 , 0 , 9.4 , 16 , 0.8870 ,
2015-02-06 19:34:44 , 324.0 , 162.0 , 28.0 , 31 , 1052 , 581 , 0 , 6 , 1 , 0 , 9.4 , 16 , 0.8870 ,
2015-02-06 19:34:45 , 324.0 , 162.0 , 28.0 , 31 , 1048 , 581 , 0 , 6 , 1 , 0 , 9.4 , 16 , 0.8870 ,
2015-02-06 19:34:47 , 324.0 , 162.0 , 28.0 , 31 , 1048 , 1004 , 1 , 6 , 1 , 1 , 9.4 , 16 , 0.8870 ,
2015-02-06 19:34:48 , 1176.2 , 1800.0 , 31.0 , 31 , 1030 , 1103 , 2 , 2 , 1 , 0 , 36.7 , 16 , 1.1500 ,
2015-02-06 19:34:49 , 1176.2 , 1800.0 , 30.0 , 31 , 1032 , 1103 , 2 , 2 , 1 , 0 , 31.8 , 16 , 1.1500 ,
2015-02-06 19:34:50 , 1162.8 , 1800.0 , 34.0 , 31 , 1031 , 1088 , 99 , 35 , 1 , 1 , 95.2 , 1 , 1.1250 ,
2015-02-06 19:34:51 , 1162.8 , 1800.0 , 36.0 , 31 , 959 , 1113 , 99 , 36 , 1 , 1 , 92.8 , 1 , 1.1250 ,
2015-02-06 19:34:52 , 1176.2 , 1800.0 , 37.0 , 31 , 949 , 1113 , 99 , 39 , 0 , 0 , 93.7 , 16 , 1.1500 ,
2015-02-06 19:34:53 , 1188.5 , 1800.0 , 38.0 , 31 , 1002 , 1113 , 99 , 35 , 0 , 1 , 95.8 , 12 , 1.1870 ,
2015-02-06 19:34:54 , 1188.5 , 1800.0 , 39.0 , 31 , 1000 , 1113 , 99 , 35 , 0 , 1 , 96.1 , 13 , 1.1870 ,
2015-02-06 19:34:55 , 1176.2 , 1800.0 , 39.0 , 31 , 947 , 1113 , 98 , 35 , 0 , 1 , 99.2 , 1 , 1.1500 ,
2015-02-06 19:34:56 , 1176.2 , 1800.0 , 40.0 , 31 , 1021 , 1113 , 99 , 35 , 0 , 1 , 97.1 , 1 , 1.1500 ,
2015-02-06 19:34:57 , 1188.5 , 1800.0 , 40.0 , 31 , 1026 , 1113 , 99 , 35 , 0 , 1 , 94.9 , 12 , 1.1870 ,
2015-02-06 19:34:58 , 1188.5 , 1800.0 , 41.0 , 31 , 961 , 1113 , 99 , 42 , 0 , 1 , 97.7 , 13 , 1.1870 ,
2015-02-06 19:34:59 , 1188.5 , 1800.0 , 41.0 , 31 , 963 , 1112 , 99 , 41 , 0 , 1 , 98.9 , 13 , 1.1870 ,
2015-02-06 19:35:00 , 1176.2 , 1800.0 , 42.0 , 31 , 965 , 1112 , 99 , 40 , 0 , 1 , 100.1 , 1 , 1.1500 ,
2015-02-06 19:35:01 , 1176.2 , 1800.0 , 42.0 , 31 , 1027 , 1112 , 99 , 38 , 0 , 1 , 100.4 , 1 , 1.1500 ,
2015-02-06 19:35:02 , 1176.2 , 1800.0 , 42.0 , 31 , 1027 , 1112 , 99 , 34 , 0 , 1 , 96.2 , 1 , 1.1500 ,
2015-02-06 19:35:03 , 1176.2 , 1800.0 , 42.0 , 31 , 1025 , 1112 , 99 , 34 , 0 , 1 , 97.1 , 1 , 1.1500 ,
2015-02-06 19:35:04 , 1188.5 , 1800.0 , 43.0 , 31 , 962 , 1112 , 99 , 34 , 0 , 1 , 99.5 , 13 , 1.1870 ,
2015-02-06 19:35:05 , 1188.5 , 1800.0 , 43.0 , 31 , 963 , 1112 , 99 , 34 , 0 , 1 , 98.1 , 13 , 1.1870 ,
2015-02-06 19:35:06 , 1188.5 , 1800.0 , 44.0 , 31 , 1027 , 1112 , 99 , 36 , 0 , 1 , 97.1 , 13 , 1.1870 ,
2015-02-06 19:35:07 , 1188.5 , 1800.0 , 44.0 , 31 , 1027 , 1112 , 99 , 36 , 0 , 1 , 97.1 , 13 , 1.1870 ,
2015-02-06 19:35:08 , 1188.5 , 1800.0 , 45.0 , 31 , 1026 , 1112 , 99 , 37 , 0 , 1 , 97.0 , 13 , 1.1870 ,
2015-02-06 19:35:09 , 1188.5 , 1800.0 , 45.0 , 31 , 966 , 1112 , 99 , 38 , 0 , 1 , 98.3 , 13 , 1.1870 ,
2015-02-06 19:35:10 , 1188.5 , 1800.0 , 45.0 , 32 , 969 , 1112 , 99 , 40 , 0 , 1 , 98.3 , 13 , 1.1870 ,
2015-02-06 19:35:11 , 1188.5 , 1800.0 , 45.0 , 32 , 968 , 1112 , 99 , 38 , 0 , 1 , 99.3 , 13 , 1.1870 ,
2015-02-06 19:35:12 , 1176.2 , 1800.0 , 45.0 , 32 , 978 , 1112 , 99 , 39 , 0 , 1 , 94.4 , 1 , 1.1500 ,
2015-02-06 19:35:13 , 1176.2 , 1800.0 , 46.0 , 32 , 978 , 1112 , 99 , 34 , 0 , 1 , 96.1 , 1 , 1.1500 ,
2015-02-06 19:35:14 , 1176.2 , 1800.0 , 46.0 , 32 , 976 , 1112 , 99 , 35 , 0 , 1 , 97.1 , 1 , 1.1500 ,
2015-02-06 19:35:15 , 1176.2 , 1800.0 , 46.0 , 32 , 980 , 1112 , 99 , 33 , 0 , 1 , 94.7 , 1 , 1.1500 ,
2015-02-06 19:35:16 , 1188.5 , 1800.0 , 47.0 , 32 , 980 , 1112 , 99 , 35 , 0 , 1 , 99.7 , 13 , 1.1870 ,
2015-02-06 19:35:17 , 1188.5 , 1800.0 , 47.0 , 33 , 1049 , 1112 , 99 , 37 , 0 , 1 , 98.9 , 13 , 1.1870 ,
2015-02-06 19:35:18 , 1188.5 , 1800.0 , 47.0 , 33 , 1051 , 1112 , 99 , 38 , 0 , 1 , 98.7 , 13 , 1.1870 ,
2015-02-06 19:35:19 , 1188.5 , 1800.0 , 48.0 , 33 , 1054 , 1112 , 99 , 38 , 0 , 1 , 97.2 , 13 , 1.1870 ,
2015-02-06 19:35:20 , 1188.5 , 1800.0 , 44.0 , 33 , 1011 , 198 , 0 , 0 , 0 , 0 , 34.1 , 12 , 1.1870 ,
2015-02-06 19:35:21 , 1188.5 , 1800.0 , 43.0 , 33 , 1024 , 209 , 0 , 0 , 0 , 0 , 33.5 , 12 , 1.1870 ,
2015-02-06 19:35:22 , 1136.7 , 1800.0 , 42.0 , 33 , 1097 , 232 , 2 , 2 , 0 , 0 , 32.0 , 16 , 1.1000 ,
2015-02-06 19:35:23 , 1136.7 , 1800.0 , 42.0 , 33 , 1099 , 232 , 2 , 2 , 0 , 0 , 31.2 , 16 , 1.1000 ,
2015-02-06 19:35:24 , 1136.7 , 1800.0 , 41.0 , 33 , 1098 , 451 , 3 , 1 , 0 , 1 , 30.7 , 16 , 1.1000 ,
2015-02-06 19:35:25 , 888.7 , 1749.6 , 40.0 , 33 , 1097 , 467 , 1 , 1 , 0 , 0 , 27.7 , 16 , 0.9750 ,
2015-02-06 19:35:26 , 888.7 , 1749.6 , 40.0 , 33 , 1096 , 496 , 0 , 1 , 0 , 0 , 27.6 , 16 , 0.9750 ,
2015-02-06 19:35:27 , 888.7 , 1749.6 , 40.0 , 33 , 1095 , 498 , 0 , 0 , 0 , 0 , 27.6 , 16 , 0.9750 ,
2015-02-06 19:35:28 , 666.4 , 405.0 , 39.0 , 33 , 1105 , 532 , 0 , 3 , 0 , 0 , 12.3 , 16 , 0.9000 ,
2015-02-06 19:35:29 , 666.4 , 405.0 , 39.0 , 33 , 1108 , 533 , 0 , 3 , 1 , 0 , 12.3 , 16 , 0.9000 ,
2015-02-06 19:35:30 , 324.0 , 162.0 , 38.0 , 33 , 1108 , 542 , 2 , 7 , 1 , 0 , 12.3 , 16 , 0.8870 ,
2015-02-06 19:35:31 , 324.0 , 162.0 , 38.0 , 33 , 1038 , 542 , 2 , 7 , 1 , 0 , 9.7 , 16 , 0.8870 ,
2015-02-06 19:35:32 , 324.0 , 162.0 , 38.0 , 33 , 1036 , 542 , 0 , 6 , 1 , 0 , 9.6 , 16 , 0.8870 ,
2015-02-06 19:35:33 , 324.0 , 162.0 , 38.0 , 33 , 1034 , 542 , 0 , 6 , 1 , 0 , 9.6 , 16 , 0.8870 ,
2015-02-06 19:35:34 , 324.0 , 162.0 , 37.0 , 33 , 1032 , 542 , 0 , 6 , 1 , 0 , 9.6 , 16 , 0.8870 ,
2015-02-06 19:35:35 , 324.0 , 162.0 , 37.0 , 33 , 1029 , 542 , 0 , 6 , 1 , 0 , 9.6 , 16 , 0.8870 ,
2015-02-06 19:35:36 , 1188.5 , 1800.0 , 42.0 , 33 , 1016 , 1738 , 98 , 39 , 1 , 0 , 81.0 , 12 , 1.1870 ,
2015-02-06 19:35:37 , 1188.5 , 1800.0 , 41.0 , 33 , 1073 , 1726 , 1 , 2 , 1 , 0 , 34.7 , 12 , 1.1870 ,
2015-02-06 19:35:38 , 1188.5 , 1800.0 , 40.0 , 33 , 1006 , 1726 , 1 , 2 , 1 , 0 , 33.6 , 12 , 1.1870 ,
2015-02-06 19:35:39 , 1188.5 , 1800.0 , 44.0 , 33 , 1071 , 1736 , 98 , 38 , 0 , 0 , 80.4 , 12 , 1.1870 ,
2015-02-06 19:35:40 , 1188.5 , 1800.0 , 46.0 , 33 , 999 , 1736 , 99 , 38 , 0 , 0 , 81.2 , 12 , 1.1870 ,
2015-02-06 19:35:41 , 1188.5 , 1800.0 , 46.0 , 33 , 1062 , 1736 , 99 , 39 , 0 , 0 , 81.6 , 12 , 1.1870 ,
2015-02-06 19:35:42 , 1188.5 , 1800.0 , 46.0 , 33 , 1061 , 1736 , 99 , 39 , 0 , 0 , 83.2 , 12 , 1.1870 ,
2015-02-06 19:35:43 , 1188.5 , 1800.0 , 46.0 , 33 , 999 , 1736 , 99 , 40 , 0 , 0 , 82.3 , 12 , 1.1870 ,
2015-02-06 19:35:44 , 1188.5 , 1800.0 , 46.0 , 33 , 1067 , 1737 , 99 , 39 , 0 , 0 , 83.1 , 12 , 1.1870 ,
2015-02-06 19:35:45 , 1188.5 , 1800.0 , 47.0 , 33 , 1001 , 1737 , 99 , 40 , 0 , 0 , 83.3 , 12 , 1.1870 ,
2015-02-06 19:35:46 , 1188.5 , 1800.0 , 47.0 , 33 , 1068 , 1737 , 99 , 41 , 0 , 0 , 87.7 , 12 , 1.1870 ,
2015-02-06 19:35:47 , 1188.5 , 1800.0 , 48.0 , 33 , 1002 , 1736 , 98 , 44 , 0 , 0 , 84.4 , 12 , 1.1870 ,
2015-02-06 19:35:48 , 1188.5 , 1800.0 , 48.0 , 33 , 1073 , 1736 , 98 , 45 , 0 , 1 , 85.9 , 12 , 1.1870 ,
2015-02-06 19:35:49 , 1188.5 , 1800.0 , 48.0 , 33 , 1010 , 1736 , 98 , 45 , 0 , 0 , 86.2 , 12 , 1.1870 ,
2015-02-06 19:35:50 , 1188.5 , 1800.0 , 48.0 , 33 , 1078 , 1736 , 98 , 43 , 0 , 1 , 84.6 , 12 , 1.1870 ,
2015-02-06 19:35:51 , 1188.5 , 1800.0 , 48.0 , 34 , 1084 , 1737 , 98 , 41 , 0 , 1 , 84.3 , 12 , 1.1870 ,
2015-02-06 19:35:52 , 1188.5 , 1800.0 , 49.0 , 34 , 1018 , 1737 , 98 , 42 , 0 , 1 , 87.1 , 12 , 1.1870 ,
2015-02-06 19:35:53 , 1188.5 , 1800.0 , 49.0 , 34 , 1022 , 1737 , 98 , 40 , 0 , 1 , 86.1 , 12 , 1.1870 ,
2015-02-06 19:35:54 , 1188.5 , 1800.0 , 49.0 , 34 , 1092 , 1737 , 98 , 43 , 0 , 1 , 89.9 , 12 , 1.1870 ,
2015-02-06 19:35:55 , 1188.5 , 1800.0 , 49.0 , 34 , 1093 , 1737 , 98 , 41 , 0 , 1 , 90.2 , 12 , 1.1870 ,
2015-02-06 19:35:56 , 1188.5 , 1800.0 , 50.0 , 34 , 1099 , 1737 , 98 , 42 , 0 , 1 , 90.2 , 12 , 1.1870 ,
2015-02-06 19:35:57 , 1188.5 , 1800.0 , 50.0 , 34 , 1104 , 1736 , 98 , 41 , 0 , 1 , 89.4 , 12 , 1.1870 ,
2015-02-06 19:35:59 , 1188.5 , 1800.0 , 50.0 , 35 , 1110 , 1736 , 98 , 41 , 0 , 1 , 90.1 , 12 , 1.1870 ,
2015-02-06 19:36:00 , 1188.5 , 1800.0 , 50.0 , 35 , 1048 , 1736 , 98 , 39 , 0 , 1 , 80.4 , 12 , 1.1870 ,
2015-02-06 19:36:01 , 1188.5 , 1800.0 , 50.0 , 35 , 1056 , 1736 , 99 , 38 , 0 , 0 , 82.6 , 12 , 1.1870 ,
2015-02-06 19:36:02 , 1188.5 , 1800.0 , 50.0 , 35 , 1130 , 1736 , 98 , 39 , 0 , 1 , 80.0 , 12 , 1.1870 ,
2015-02-06 19:36:03 , 1188.5 , 1800.0 , 51.0 , 35 , 1063 , 1736 , 98 , 40 , 0 , 1 , 81.0 , 12 , 1.1870 ,
2015-02-06 19:36:04 , 1188.5 , 1800.0 , 51.0 , 35 , 1067 , 1736 , 99 , 39 , 0 , 0 , 81.1 , 12 , 1.1870 ,
2015-02-06 19:36:05 , 1188.5 , 1800.0 , 51.0 , 35 , 1140 , 1736 , 99 , 42 , 0 , 0 , 89.3 , 12 , 1.1870 ,
2015-02-06 19:36:06 , 1188.5 , 1800.0 , 51.0 , 35 , 1071 , 1736 , 99 , 42 , 0 , 0 , 89.1 , 12 , 1.1870 ,
2015-02-06 19:36:07 , 1188.5 , 1800.0 , 52.0 , 35 , 1076 , 1736 , 99 , 44 , 0 , 0 , 86.8 , 12 , 1.1870 ,
2015-02-06 19:36:08 , 1188.5 , 1800.0 , 52.0 , 36 , 1151 , 1736 , 99 , 42 , 0 , 0 , 87.8 , 12 , 1.1870 ,
2015-02-06 19:36:09 , 1188.5 , 1800.0 , 52.0 , 36 , 1155 , 1736 , 98 , 40 , 0 , 1 , 88.8 , 12 , 1.1870 ,
2015-02-06 19:36:10 , 1188.5 , 1800.0 , 52.0 , 36 , 1158 , 1736 , 99 , 41 , 0 , 0 , 89.5 , 12 , 1.1870 ,
2015-02-06 19:36:11 , 1188.5 , 1800.0 , 52.0 , 36 , 1163 , 1736 , 99 , 41 , 0 , 0 , 87.0 , 12 , 1.1870 ,
2015-02-06 19:36:12 , 1188.5 , 1800.0 , 53.0 , 36 , 0 , 1736 , 99 , 39 , 0 , 0 , 82.1 , 12 , 1.1870 ,
2015-02-06 19:36:13 , 1188.5 , 1800.0 , 53.0 , 36 , 1173 , 1736 , 98 , 43 , 0 , 1 , 87.0 , 12 , 1.1870 ,
2015-02-06 19:36:14 , 1188.5 , 1800.0 , 53.0 , 36 , 1102 , 1736 , 98 , 44 , 0 , 1 , 86.5 , 12 , 1.1870 ,
2015-02-06 19:36:15 , 1188.5 , 1800.0 , 53.0 , 36 , 1104 , 1736 , 99 , 46 , 0 , 1 , 89.3 , 12 , 1.1870 ,
2015-02-06 19:36:16 , 1188.5 , 1800.0 , 53.0 , 36 , 1182 , 1736 , 99 , 37 , 0 , 0 , 79.9 , 12 , 1.1870 ,
2015-02-06 19:36:17 , 1188.5 , 1800.0 , 54.0 , 36 , 1186 , 1736 , 99 , 38 , 0 , 0 , 83.1 , 12 , 1.1870 ,
2015-02-06 19:36:18 , 1188.5 , 1800.0 , 53.0 , 37 , 1115 , 1736 , 99 , 38 , 0 , 0 , 83.4 , 12 , 1.1870 ,
2015-02-06 19:36:19 , 1188.5 , 1800.0 , 53.0 , 37 , 1191 , 1736 , 99 , 39 , 0 , 0 , 82.4 , 12 , 1.1870 ,
2015-02-06 19:36:20 , 1188.5 , 1800.0 , 54.0 , 37 , 1123 , 1736 , 99 , 37 , 0 , 0 , 82.5 , 12 , 1.1870 ,
2015-02-06 19:36:21 , 1188.5 , 1800.0 , 54.0 , 37 , 1197 , 1736 , 99 , 37 , 0 , 0 , 82.4 , 12 , 1.1870 ,
2015-02-06 19:36:22 , 1188.5 , 1800.0 , 51.0 , 37 , 1206 , 1751 , 21 , 8 , 0 , 2 , 45.9 , 12 , 1.1870 ,
2015-02-06 19:36:23 , 1188.5 , 1800.0 , 49.0 , 37 , 1216 , 215 , 0 , 0 , 0 , 0 , 34.3 , 12 , 1.1870 ,
2015-02-06 19:36:24 , 1188.5 , 1800.0 , 48.0 , 37 , 1219 , 250 , 2 , 2 , 0 , 0 , 34.7 , 12 , 1.1870 ,
2015-02-06 19:36:25 , 1084.5 , 1800.0 , 47.0 , 37 , 1142 , 250 , 2 , 2 , 0 , 0 , 30.4 , 16 , 1.0500 ,
2015-02-06 19:36:26 , 1084.5 , 1800.0 , 46.0 , 37 , 1142 , 252 , 0 , 1 , 0 , 0 , 30.0 , 16 , 1.0500 ,
2015-02-06 19:36:27 , 1084.5 , 1800.0 , 46.0 , 37 , 1143 , 280 , 1 , 2 , 0 , 0 , 30.2 , 16 , 1.0500 ,
2015-02-06 19:36:28 , 888.7 , 1749.6 , 46.0 , 37 , 1138 , 280 , 2 , 2 , 0 , 0 , 28.3 , 16 , 0.9750 ,
2015-02-06 19:36:29 , 888.7 , 1749.6 , 45.0 , 37 , 1137 , 280 , 0 , 1 , 0 , 0 , 28.1 , 16 , 0.9750 ,
2015-02-06 19:36:30 , 666.4 , 405.0 , 45.0 , 37 , 1218 , 265 , 5 , 6 , 0 , 2 , 16.1 , 16 , 0.9000 ,
2015-02-06 19:36:31 , 666.4 , 405.0 , 44.0 , 37 , 1221 , 265 , 5 , 6 , 1 , 2 , 13.0 , 16 , 0.9000 ,
2015-02-06 19:36:32 , 666.4 , 405.0 , 44.0 , 37 , 1224 , 265 , 5 , 7 , 1 , 2 , 13.0 , 16 , 0.9000 ,
2015-02-06 19:36:33 , 324.0 , 162.0 , 43.0 , 37 , 1228 , 265 , 13 , 16 , 1 , 2 , 12.9 , 16 , 0.8870 ,
2015-02-06 19:36:34 , 324.0 , 162.0 , 43.0 , 37 , 1222 , 265 , 13 , 15 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:35 , 324.0 , 162.0 , 43.0 , 37 , 1214 , 265 , 14 , 16 , 1 , 2 , 10.4 , 16 , 0.8870 ,
2015-02-06 19:36:36 , 324.0 , 162.0 , 42.0 , 37 , 1215 , 265 , 14 , 16 , 1 , 2 , 10.4 , 16 , 0.8870 ,
2015-02-06 19:36:37 , 324.0 , 162.0 , 42.0 , 36 , 1209 , 265 , 14 , 16 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:38 , 324.0 , 162.0 , 42.0 , 36 , 1133 , 265 , 13 , 16 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:39 , 324.0 , 162.0 , 42.0 , 36 , 1130 , 265 , 12 , 15 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:40 , 324.0 , 162.0 , 42.0 , 36 , 1205 , 265 , 12 , 14 , 1 , 1 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:41 , 324.0 , 162.0 , 41.0 , 36 , 1126 , 265 , 14 , 16 , 1 , 2 , 10.2 , 16 , 0.8870 ,
2015-02-06 19:36:42 , 324.0 , 162.0 , 41.0 , 36 , 1125 , 265 , 14 , 16 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:43 , 324.0 , 162.0 , 40.0 , 36 , 1197 , 265 , 13 , 16 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:44 , 324.0 , 162.0 , 40.0 , 36 , 1120 , 265 , 14 , 16 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:45 , 324.0 , 162.0 , 40.0 , 36 , 1195 , 265 , 14 , 16 , 1 , 2 , 10.2 , 16 , 0.8870 ,
2015-02-06 19:36:46 , 324.0 , 162.0 , 40.0 , 36 , 1119 , 265 , 13 , 16 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:47 , 324.0 , 162.0 , 40.0 , 35 , 1189 , 265 , 13 , 15 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:48 , 324.0 , 162.0 , 39.0 , 35 , 1112 , 265 , 13 , 16 , 1 , 2 , 10.3 , 16 , 0.8870 ,
2015-02-06 19:36:49 , 1084.5 , 1800.0 , 40.0 , 35 , 1177 , 233 , 16 , 1 , 1 , 10 , 26.7 , 16 , 1.0500 ,
2015-02-06 19:36:50 , 1084.5 , 1800.0 , 40.0 , 35 , 1163 , 244 , 0 , 0 , 1 , 0 , 29.6 , 16 , 1.0500 ,
2015-02-06 19:36:51 , 1084.5 , 1800.0 , 41.0 , 35 , 1163 , 268 , 2 , 2 , 1 , 0 , 29.9 , 16 , 1.0500 ,
2015-02-06 19:36:52 , 1084.5 , 1800.0 , 40.0 , 35 , 1161 , 268 , 1 , 2 , 1 , 0 , 29.9 , 16 , 1.0500 ,
2015-02-06 19:36:53 , 888.7 , 1749.6 , 40.0 , 35 , 1161 , 268 , 0 , 0 , 1 , 0 , 27.7 , 16 , 0.9750 ,
2015-02-06 19:36:54 , 888.7 , 1749.6 , 40.0 , 35 , 1160 , 319 , 1 , 0 , 0 , 0 , 27.6 , 16 , 0.9750 ,
2015-02-06 19:36:55 , 888.7 , 1749.6 , 40.0 , 35 , 1159 , 591 , 2 , 0 , 0 , 0 , 27.7 , 16 , 0.9750 ,
2015-02-06 19:36:56 , 666.4 , 405.0 , 39.0 , 35 , 1170 , 604 , 1 , 4 , 0 , 0 , 12.4 , 16 , 0.9000 ,
2015-02-06 19:36:57 , 666.4 , 405.0 , 39.0 , 35 , 1099 , 654 , 4 , 3 , 1 , 2 , 12.4 , 16 , 0.9000 ,
2015-02-06 19:36:58 , 324.0 , 162.0 , 39.0 , 35 , 1095 , 667 , 2 , 5 , 1 , 0 , 12.4 , 16 , 0.8870 ,
2015-02-06 19:36:59 , 324.0 , 162.0 , 38.0 , 35 , 1093 , 674 , 4 , 8 , 1 , 1 , 9.7 , 16 , 0.8870 ,
2015-02-06 19:37:00 , 324.0 , 162.0 , 38.0 , 35 , 1091 , 674 , 0 , 6 , 1 , 0 , 9.6 , 16 , 0.8870 ,
2015-02-06 19:37:01 , 324.0 , 162.0 , 38.0 , 34 , 1087 , 674 , 3 , 8 , 1 , 0 , 9.7 , 16 , 0.8870 ,
2015-02-06 19:37:03 , 324.0 , 162.0 , 38.0 , 34 , 1083 , 683 , 8 , 10 , 1 , 2 , 9.7 , 16 , 0.8870 ,
2015-02-06 19:37:04 , 324.0 , 162.0 , 37.0 , 34 , 1078 , 683 , 2 , 8 , 1 , 0 , 9.6 , 16 , 0.8870 ,
2015-02-06 19:37:05 , 324.0 , 162.0 , 37.0 , 34 , 1167 , 683 , 4 , 9 , 1 , 0 , 9.7 , 16 , 0.8870 ,
2015-02-06 19:37:06 , 324.0 , 162.0 , 37.0 , 34 , 1098 , 683 , 0 , 6 , 1 , 0 , 9.7 , 16 , 0.8870 ,
2015-02-06 19:37:07 , 324.0 , 162.0 , 37.0 , 34 , 1092 , 683 , 0 , 6 , 1 , 0 , 9.7 , 16 , 0.8870 ,
2015-02-06 19:37:08 , 324.0 , 162.0 , 37.0 , 34 , 1084 , 683 , 0 , 6 , 1 , 0 , 9.6 , 16 , 0.8870 ,
2015-02-06 19:37:09 , 324.0 , 162.0 , 37.0 , 34 , 1078 , 683 , 0 , 6 , 1 , 0 , 9.6 , 16 , 0.8870 ,
2015-02-06 19:37:10 , 1188.5 , 1800.0 , 43.0 , 34 , 1125 , 1584 , 98 , 40 , 1 , 1 , 87.4 , 13 , 1.1870 ,
2015-02-06 19:37:11 , 1188.5 , 1800.0 , 40.0 , 34 , 1046 , 1570 , 1 , 2 , 1 , 0 , 33.9 , 12 , 1.1870 ,
2015-02-06 19:37:12 , 1188.5 , 1800.0 , 39.0 , 34 , 1044 , 1570 , 0 , 0 , 1 , 0 , 33.2 , 12 , 1.1870 ,
2015-02-06 19:37:13 , 1188.5 , 1800.0 , 44.0 , 34 , 1038 , 1561 , 99 , 40 , 0 , 1 , 92.0 , 13 , 1.1870 ,
2015-02-06 19:37:14 , 1188.5 , 1800.0 , 45.0 , 34 , 1030 , 1578 , 99 , 38 , 0 , 1 , 91.8 , 12 , 1.1870 ,
2015-02-06 19:37:15 , 1188.5 , 1800.0 , 46.0 , 34 , 1024 , 1578 , 99 , 40 , 0 , 1 , 92.5 , 12 , 1.1870 ,
2015-02-06 19:37:16 , 1188.5 , 1800.0 , 46.0 , 34 , 1022 , 1576 , 99 , 40 , 0 , 1 , 90.6 , 12 , 1.1870 ,
2015-02-06 19:37:17 , 1188.5 , 1800.0 , 46.0 , 34 , 1024 , 1576 , 99 , 40 , 0 , 1 , 92.8 , 12 , 1.1870 ,
2015-02-06 19:37:18 , 1188.5 , 1800.0 , 47.0 , 34 , 1094 , 1576 , 99 , 40 , 0 , 1 , 92.7 , 12 , 1.1870 ,
2015-02-06 19:37:19 , 1188.5 , 1800.0 , 47.0 , 34 , 1096 , 1576 , 99 , 40 , 0 , 1 , 92.8 , 12 , 1.1870 ,
2015-02-06 19:37:20 , 1188.5 , 1800.0 , 47.0 , 34 , 1099 , 1576 , 99 , 40 , 0 , 1 , 92.0 , 12 , 1.1870 ,
2015-02-06 19:37:21 , 1188.5 , 1800.0 , 48.0 , 34 , 1101 , 1576 , 99 , 36 , 0 , 1 , 91.8 , 12 , 1.1870 ,
2015-02-06 19:37:22 , 1188.5 , 1800.0 , 48.0 , 34 , 1103 , 1578 , 99 , 40 , 0 , 1 , 90.1 , 12 , 1.1870 ,
2015-02-06 19:37:23 , 1188.5 , 1800.0 , 48.0 , 34 , 1106 , 1578 , 99 , 37 , 0 , 1 , 91.3 , 12 , 1.1870 ,
2015-02-06 19:37:24 , 1188.5 , 1800.0 , 49.0 , 34 , 1107 , 1578 , 99 , 41 , 0 , 1 , 91.0 , 12 , 1.1870 ,
2015-02-06 19:37:25 , 1188.5 , 1800.0 , 49.0 , 34 , 1039 , 1577 , 99 , 42 , 0 , 1 , 92.0 , 12 , 1.1870 ,
2015-02-06 19:37:26 , 1188.5 , 1800.0 , 50.0 , 34 , 1041 , 1577 , 99 , 42 , 0 , 1 , 91.7 , 12 , 1.1870 ,
2015-02-06 19:37:27 , 1188.5 , 1800.0 , 49.0 , 34 , 1041 , 1577 , 99 , 41 , 0 , 1 , 93.5 , 12 , 1.1870 ,
2015-02-06 19:37:28 , 1188.5 , 1800.0 , 50.0 , 34 , 1112 , 1577 , 99 , 41 , 0 , 1 , 93.3 , 12 , 1.1870 ,
2015-02-06 19:37:29 , 1188.5 , 1800.0 , 50.0 , 35 , 1116 , 1577 , 99 , 39 , 0 , 1 , 93.1 , 12 , 1.1870 ,
2015-02-06 19:37:30 , 1188.5 , 1800.0 , 51.0 , 35 , 1050 , 1577 , 99 , 39 , 0 , 1 , 93.2 , 12 , 1.1870 ,
2015-02-06 19:37:31 , 1188.5 , 1800.0 , 50.0 , 35 , 1055 , 1577 , 99 , 39 , 0 , 1 , 92.2 , 12 , 1.1870 ,
2015-02-06 19:37:32 , 1188.5 , 1800.0 , 49.0 , 35 , 1135 , 1594 , 12 , 3 , 0 , 2 , 53.6 , 12 , 1.1870 ,
2015-02-06 19:37:33 , 1188.5 , 1800.0 , 46.0 , 35 , 1152 , 323 , 1 , 0 , 0 , 0 , 34.5 , 12 , 1.1870 ,
2015-02-06 19:37:34 , 1188.5 , 1800.0 , 46.0 , 35 , 1157 , 335 , 6 , 2 , 0 , 0 , 34.7 , 12 , 1.1870 ,
2015-02-06 19:37:35 , 1188.5 , 1800.0 , 45.0 , 35 , 0 , 322 , 2 , 0 , 0 , 0 , 34.1 , 12 , 1.1870 ,
2015-02-06 19:37:36 , 1188.5 , 1800.0 , 45.0 , 35 , 1085 , 319 , 2 , 0 , 0 , 0 , 34.0 , 12 , 1.1870 ,
2015-02-06 19:37:37 , 1188.5 , 1800.0 , 45.0 , 35 , 1085 , 390 , 5 , 1 , 0 , 1 , 34.0 , 12 , 1.1870 ,
2015-02-06 19:37:38 , 1188.5 , 1800.0 , 45.0 , 35 , 1083 , 421 , 5 , 1 , 0 , 2 , 34.2 , 12 , 1.1870 ,
2015-02-06 19:37:39 , 1188.5 , 1800.0 , 44.0 , 35 , 1082 , 396 , 6 , 1 , 0 , 2 , 34.4 , 12 , 1.1870 ,
2015-02-06 19:37:40 , 1188.5 , 1800.0 , 44.0 , 35 , 1082 , 411 , 3 , 0 , 0 , 0 , 34.0 , 12 , 1.1870 ,
2015-02-06 19:37:41 , 1188.5 , 1800.0 , 44.0 , 35 , 1154 , 409 , 1 , 0 , 0 , 0 , 33.8 , 12 , 1.1870 ,
2015-02-06 19:37:42 , 1188.5 , 1800.0 , 44.0 , 35 , 1153 , 400 , 1 , 0 , 0 , 0 , 33.8 , 12 , 1.1870 ,
2015-02-06 19:37:43 , 1188.5 , 1800.0 , 44.0 , 35 , 1152 , 401 , 1 , 0 , 0 , 0 , 33.7 , 12 , 1.1870 ,
2015-02-06 19:37:44 , 1188.5 , 1800.0 , 44.0 , 35 , 1154 , 403 , 0 , 0 , 0 , 0 , 33.7 , 12 , 1.1870 ,
2015-02-06 19:37:45 , 1188.5 , 1800.0 , 44.0 , 35 , 1081 , 419 , 1 , 0 , 0 , 0 , 33.7 , 12 , 1.1870 ,
2015-02-06 19:37:46 , 888.7 , 1749.6 , 43.0 , 35 , 1081 , 405 , 1 , 0 , 0 , 0 , 27.7 , 16 , 0.9750 ,
2015-02-06 19:37:47 , 888.7 , 1749.6 , 42.0 , 35 , 1080 , 417 , 1 , 0 , 0 , 0 , 27.8 , 16 , 0.9750 ,
2015-02-06 19:37:48 , 666.4 , 405.0 , 42.0 , 35 , 1106 , 413 , 2 , 2 , 0 , 0 , 13.3 , 16 , 0.9000 ,
2015-02-06 19:37:49 , 666.4 , 405.0 , 41.0 , 35 , 1198 , 402 , 2 , 2 , 0 , 0 , 12.4 , 16 , 0.9000 ,
2015-02-06 19:37:50 , 666.4 , 405.0 , 41.0 , 35 , 1120 , 404 , 2 , 2 , 0 , 0 , 12.3 , 16 , 0.9000 ,
2015-02-06 19:37:51 , 324.0 , 162.0 , 40.0 , 35 , 1193 , 401 , 4 , 4 , 0 , 1 , 12.4 , 16 , 0.8870 ,
2015-02-06 19:37:52 , 324.0 , 162.0 , 40.0 , 35 , 1111 , 414 , 3 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:37:53 , 324.0 , 162.0 , 40.0 , 35 , 1106 , 408 , 3 , 5 , 0 , 0 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:37:54 , 324.0 , 162.0 , 40.0 , 35 , 1173 , 416 , 5 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:37:55 , 324.0 , 162.0 , 39.0 , 35 , 1170 , 419 , 5 , 5 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:37:56 , 324.0 , 162.0 , 39.0 , 35 , 1163 , 401 , 4 , 5 , 0 , 1 , 6.6 , 16 , 0.8870 ,
2015-02-06 19:37:57 , 324.0 , 162.0 , 39.0 , 35 , 1160 , 409 , 5 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:37:58 , 324.0 , 162.0 , 39.0 , 34 , 1156 , 402 , 4 , 4 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:37:59 , 324.0 , 162.0 , 39.0 , 34 , 1153 , 395 , 4 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:38:00 , 324.0 , 162.0 , 38.0 , 34 , 1151 , 401 , 4 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:38:01 , 324.0 , 162.0 , 38.0 , 34 , 1076 , 406 , 5 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:38:02 , 324.0 , 162.0 , 38.0 , 34 , 1070 , 415 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:03 , 324.0 , 162.0 , 38.0 , 34 , 1141 , 411 , 4 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:38:04 , 324.0 , 162.0 , 37.0 , 34 , 1069 , 417 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:05 , 324.0 , 162.0 , 38.0 , 34 , 1066 , 411 , 6 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:38:06 , 324.0 , 162.0 , 37.0 , 34 , 1135 , 403 , 4 , 5 , 0 , 1 , 6.6 , 16 , 0.8870 ,
2015-02-06 19:38:07 , 324.0 , 162.0 , 37.0 , 34 , 1060 , 403 , 5 , 5 , 0 , 0 , 6.6 , 16 , 0.8870 ,
2015-02-06 19:38:08 , 324.0 , 162.0 , 37.0 , 34 , 1127 , 405 , 2 , 4 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:09 , 324.0 , 162.0 , 37.0 , 34 , 1055 , 422 , 5 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:38:10 , 324.0 , 162.0 , 37.0 , 34 , 1054 , 414 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:11 , 324.0 , 162.0 , 36.0 , 33 , 1121 , 419 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:12 , 324.0 , 162.0 , 36.0 , 33 , 1049 , 413 , 5 , 5 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:14 , 324.0 , 162.0 , 36.0 , 33 , 1048 , 405 , 4 , 5 , 0 , 1 , 6.6 , 16 , 0.8870 ,
2015-02-06 19:38:15 , 324.0 , 162.0 , 36.0 , 33 , 1115 , 404 , 4 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:16 , 324.0 , 162.0 , 36.0 , 33 , 1112 , 404 , 1 , 4 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:17 , 324.0 , 162.0 , 36.0 , 33 , 1043 , 419 , 4 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:38:18 , 324.0 , 162.0 , 35.0 , 33 , 1039 , 410 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:19 , 324.0 , 162.0 , 35.0 , 33 , 1038 , 418 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:20 , 324.0 , 162.0 , 35.0 , 33 , 1035 , 415 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:21 , 324.0 , 162.0 , 35.0 , 33 , 1034 , 406 , 5 , 5 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:22 , 324.0 , 162.0 , 35.0 , 33 , 1031 , 407 , 4 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:23 , 324.0 , 162.0 , 35.0 , 32 , 1028 , 407 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:24 , 324.0 , 162.0 , 35.0 , 32 , 1026 , 421 , 4 , 5 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:25 , 324.0 , 162.0 , 35.0 , 32 , 1024 , 407 , 2 , 4 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:26 , 324.0 , 162.0 , 35.0 , 32 , 1021 , 420 , 4 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:27 , 324.0 , 162.0 , 35.0 , 32 , 1088 , 419 , 4 , 5 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:28 , 324.0 , 162.0 , 34.0 , 32 , 1088 , 405 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:29 , 324.0 , 162.0 , 34.0 , 32 , 1016 , 410 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:30 , 324.0 , 162.0 , 34.0 , 32 , 1015 , 406 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:31 , 324.0 , 162.0 , 34.0 , 32 , 1081 , 397 , 4 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:32 , 324.0 , 162.0 , 34.0 , 32 , 1012 , 401 , 1 , 4 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:33 , 324.0 , 162.0 , 34.0 , 32 , 1009 , 408 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:34 , 324.0 , 162.0 , 34.0 , 32 , 1073 , 418 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:35 , 324.0 , 162.0 , 34.0 , 32 , 1003 , 416 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:36 , 324.0 , 162.0 , 34.0 , 32 , 1069 , 418 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:37 , 324.0 , 162.0 , 34.0 , 32 , 1001 , 409 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:38 , 324.0 , 162.0 , 33.0 , 31 , 1065 , 400 , 4 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:39 , 324.0 , 162.0 , 33.0 , 31 , 1063 , 403 , 6 , 5 , 0 , 1 , 6.2 , 16 , 0.8870 ,
2015-02-06 19:38:40 , 324.0 , 162.0 , 33.0 , 31 , 995 , 405 , 4 , 5 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:41 , 324.0 , 162.0 , 33.0 , 31 , 1060 , 417 , 4 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:42 , 324.0 , 162.0 , 33.0 , 31 , 994 , 412 , 4 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:43 , 324.0 , 162.0 , 33.0 , 31 , 992 , 420 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:44 , 324.0 , 162.0 , 33.0 , 31 , 1056 , 410 , 5 , 5 , 0 , 1 , 6.2 , 16 , 0.8870 ,
2015-02-06 19:38:45 , 324.0 , 162.0 , 33.0 , 31 , 1055 , 416 , 3 , 5 , 0 , 0 , 6.2 , 16 , 0.8870 ,
2015-02-06 19:38:46 , 324.0 , 162.0 , 33.0 , 31 , 989 , 413 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:47 , 324.0 , 162.0 , 33.0 , 31 , 986 , 414 , 3 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:48 , 324.0 , 162.0 , 33.0 , 31 , 1050 , 398 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:49 , 324.0 , 162.0 , 33.0 , 31 , 1049 , 403 , 5 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:38:50 , 324.0 , 162.0 , 32.0 , 31 , 1050 , 414 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:51 , 324.0 , 162.0 , 32.0 , 31 , 983 , 410 , 4 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:52 , 324.0 , 162.0 , 32.0 , 31 , 982 , 419 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:53 , 324.0 , 162.0 , 32.0 , 31 , 982 , 416 , 4 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:54 , 324.0 , 162.0 , 32.0 , 31 , 982 , 412 , 3 , 4 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:55 , 324.0 , 162.0 , 32.0 , 31 , 1046 , 399 , 4 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:38:56 , 324.0 , 162.0 , 32.0 , 31 , 1046 , 399 , 4 , 4 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:38:57 , 324.0 , 162.0 , 32.0 , 31 , 1044 , 414 , 4 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:58 , 324.0 , 162.0 , 32.0 , 31 , 1047 , 416 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:38:59 , 324.0 , 162.0 , 32.0 , 31 , 1045 , 406 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:00 , 324.0 , 162.0 , 32.0 , 31 , 979 , 409 , 4 , 5 , 0 , 0 , 6.2 , 16 , 0.8870 ,
2015-02-06 19:39:01 , 324.0 , 162.0 , 32.0 , 31 , 978 , 406 , 3 , 5 , 0 , 1 , 6.2 , 16 , 0.8870 ,
2015-02-06 19:39:02 , 324.0 , 162.0 , 32.0 , 31 , 977 , 419 , 4 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:03 , 324.0 , 162.0 , 32.0 , 31 , 979 , 409 , 3 , 4 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:04 , 324.0 , 162.0 , 31.0 , 31 , 978 , 418 , 5 , 5 , 0 , 1 , 6.5 , 16 , 0.8870 ,
2015-02-06 19:39:05 , 324.0 , 162.0 , 31.0 , 31 , 977 , 421 , 5 , 5 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:06 , 324.0 , 162.0 , 31.0 , 31 , 980 , 404 , 4 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:07 , 324.0 , 162.0 , 31.0 , 31 , 1048 , 410 , 5 , 5 , 0 , 1 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:08 , 324.0 , 162.0 , 31.0 , 31 , 1048 , 406 , 4 , 5 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:09 , 324.0 , 162.0 , 31.0 , 31 , 1048 , 416 , 3 , 5 , 0 , 1 , 6.2 , 16 , 0.8870 ,
2015-02-06 19:39:10 , 324.0 , 162.0 , 31.0 , 31 , 1047 , 413 , 4 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:11 , 324.0 , 162.0 , 31.0 , 31 , 982 , 420 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:12 , 324.0 , 162.0 , 31.0 , 31 , 982 , 396 , 5 , 5 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:13 , 324.0 , 162.0 , 31.0 , 31 , 980 , 405 , 5 , 5 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:14 , 324.0 , 162.0 , 31.0 , 31 , 979 , 414 , 5 , 5 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:15 , 324.0 , 162.0 , 31.0 , 31 , 1044 , 410 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:16 , 324.0 , 162.0 , 31.0 , 31 , 1044 , 415 , 3 , 5 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:17 , 324.0 , 162.0 , 31.0 , 31 , 1044 , 415 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:18 , 324.0 , 162.0 , 31.0 , 31 , 1044 , 413 , 5 , 5 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:19 , 324.0 , 162.0 , 31.0 , 31 , 1042 , 424 , 4 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:20 , 324.0 , 162.0 , 31.0 , 31 , 1042 , 404 , 6 , 5 , 0 , 1 , 6.6 , 16 , 0.8870 ,
2015-02-06 19:39:21 , 324.0 , 162.0 , 31.0 , 31 , 1042 , 412 , 5 , 5 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:22 , 324.0 , 162.0 , 31.0 , 31 , 1043 , 408 , 5 , 5 , 0 , 1 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:23 , 324.0 , 162.0 , 30.0 , 31 , 1042 , 419 , 3 , 5 , 0 , 0 , 6.3 , 16 , 0.8870 ,
2015-02-06 19:39:24 , 324.0 , 162.0 , 30.0 , 31 , 977 , 414 , 4 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:25 , 324.0 , 162.0 , 30.0 , 31 , 976 , 414 , 1 , 4 , 0 , 0 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:27 , 324.0 , 162.0 , 30.0 , 31 , 974 , 402 , 5 , 5 , 0 , 1 , 6.4 , 16 , 0.8870 ,
2015-02-06 19:39:28 , 324.0 , 162.0 , 30.0 , 31 , 1039 , 372 , 26 , 18 , 0 , 4 , 8.3 , 16 , 0.8870 ,
2015-02-06 19:39:29 , 324.0 , 162.0 , 30.0 , 31 , 976 , 330 , 10 , 8 , 0 , 1 , 6.7 , 16 , 0.8870 ,
2015-02-06 19:39:30 , 324.0 , 162.0 , 30.0 , 31 , 975 , 211 , 8 , 9 , 0 , 1 , 7.3 , 16 , 0.8870 ,
2015-02-06 19:39:31 , 324.0 , 162.0 , 30.0 , 31 , 976 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:32 , 324.0 , 162.0 , 30.0 , 31 , 976 , 210 , 2 , 4 , 0 , 0 , 6.2 , 16 , 0.8870 ,
2015-02-06 19:39:33 , 324.0 , 162.0 , 30.0 , 31 , 975 , 212 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:34 , 324.0 , 162.0 , 30.0 , 31 , 979 , 210 , 2 , 4 , 0 , 1 , 7.1 , 16 , 0.8870 ,
2015-02-06 19:39:35 , 324.0 , 162.0 , 30.0 , 31 , 1044 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:36 , 324.0 , 162.0 , 30.0 , 31 , 980 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:37 , 324.0 , 162.0 , 30.0 , 31 , 1045 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:38 , 324.0 , 162.0 , 30.0 , 31 , 1045 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:39 , 324.0 , 162.0 , 30.0 , 31 , 1043 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:40 , 324.0 , 162.0 , 30.0 , 31 , 1049 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:41 , 324.0 , 162.0 , 30.0 , 31 , 984 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:42 , 324.0 , 162.0 , 30.0 , 31 , 982 , 210 , 2 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:43 , 324.0 , 162.0 , 30.0 , 31 , 982 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:44 , 324.0 , 162.0 , 30.0 , 31 , 982 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:45 , 324.0 , 162.0 , 30.0 , 31 , 1045 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:46 , 324.0 , 162.0 , 29.0 , 31 , 1046 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:47 , 324.0 , 162.0 , 30.0 , 31 , 1046 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:48 , 324.0 , 162.0 , 30.0 , 31 , 1045 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:49 , 324.0 , 162.0 , 29.0 , 31 , 1045 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:50 , 324.0 , 162.0 , 29.0 , 31 , 981 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:51 , 324.0 , 162.0 , 29.0 , 31 , 979 , 210 , 0 , 4 , 0 , 0 , 6.2 , 16 , 0.8870 ,
2015-02-06 19:39:52 , 324.0 , 162.0 , 29.0 , 31 , 979 , 210 , 1 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:53 , 324.0 , 162.0 , 29.0 , 31 , 979 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:54 , 324.0 , 162.0 , 29.0 , 31 , 980 , 210 , 3 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:55 , 324.0 , 162.0 , 29.0 , 31 , 978 , 210 , 2 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:56 , 324.0 , 162.0 , 29.0 , 31 , 1044 , 210 , 1 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
2015-02-06 19:39:57 , 324.0 , 162.0 , 29.0 , 31 , 1042 , 210 , 0 , 4 , 0 , 0 , 6.1 , 16 , 0.8870 ,
Do you happen to have a PCI-E capture card fitted? Or any other PCI-E devices, apart from graphics cards, installed?
A friend of mine had a similar problem of half his normal GPU score in firemark. We solved it eventually by removing his avermedia PCI-E capture card.
No mate, one GPU and that's it. Head scratcher aint' it lol.
Ye, these type of problem can be really tricky to diagnose. My friend had no problems with the exact same setup on windows 7 - it was only when he updated to 8.1 that he had this issue with his capture card.
Are you on windows 8.1? If so, if you happen to have another drive that you could temporarily use as a boot drive, you could try putting windows 7 on it and see if the problem persists.
You are going to laugh at this. I just checked your links again. Your original is Firestrike normal and your one with the score halved is Firestrike Extreme. You can rest easy now your system is fine lol.
tried system restore to before it crashed/boot problems?
also tried reflashing the bios/load optimised defaults and re enter oc
edit nvm think you solved it
Even my missus is sat here ****ing herself. What a helmet!
Thanks mate, couldn't see the wood for the trees! Got so hung up this bloody boot problem I was rushing to find the fault :D
Just ran http://www.3dmark.com/fs/4002504
:D
Despite me being a knob end and comparing two different fire strike scores I've ran into yet more problems.
I got half way through restoring my steam library and got a "Steam cannot allocate enough disk space" error. Random, it was ten gig into a 2 TB drive. Kicked the download off again and the system hung. Arghhh!
Rebooted and had a pop up from GeForce experience telling me a new drivers was available, got halfway through downloading the driver and GeForce experience crashed but left crazy trails across the desktop along with pretty mouse pointer trails too lol
Another reboot and back to square one. Pc locks up on boot and can't write to either drive along with random graphical glitches. The thing that's getting on my **** is I solve one problem and immediately encounter another. Gotta love PC Gaming!
Back to Overclockers for some RMA style lovin' :-D
