Hello, just wondering is someone could run ultra for me to test if boost is working ok on an overclocked Maxwell in graphics test 1.
On graphics test 1 my GPUs seem to run about 200 mhz slower, its like the boost clock isnt on or something. For all the other tests it works fine, also in firestrike extreme and normal its also working fine along with all my games and other benchmarks.
I just wanted to compare my firestrike ultra with my crossfire setup, i'll just disable boost later and test it but i thought i would ask if you guys are getting the same result or if its just mine. I might just need to reinstall drivers/3dmark or summat.
Cheers.
Cheers.
the only thing limiting the power is the 1.28 limit on the chip.
