Ok, the situation is as follows, I have a mailman server internally on our network which has been working fine up until saturday when we had a powercut, since then I cannot communicate to it externally on any port.
I've checked the firewall rules for 25 and also setup port 80 to test the apache on there but neither of these work. I've checked selinux which is disabled and I've rebooted again to no avail.
However, I can ssh/telnet/http to it on the same subnet on my local lan and it works fine but not from outside of the firewall, but it's not the firewall (as far as i can tell) because I have RDP rules set up amoungst others which are working fine, same reason why I don't think it's the routing.
I'm a linux noob and once again I've been thrown in at the deep end, does anyone have any pointers?
/edit firewall is debian running shoreline, mailman is also a debian box.
