Firewall question
21 Aug 2006
If i am using avast, is the windows firewall sufficient as a firewall? router also has a firewall but no idea how to update it (or if it is necessary to update firewalls like AV?) :confused:
if you've got a router, then windows firewall is fine
unless you go installing viruses and crap all the time
Main reason i have a firewall is for outgoing traffic actually, when some naughty little program tries to send out info from my system.
Also, seem a lot more configurable.
1st up, no you don't need to update your routers firewall, just check it is enabled.
Then as bledd. said, use windows firewall
