27 Oct 2013 at 12:23 #1 Tattooed Tattooed Associate Joined 14 Aug 2003 Posts 2,002 Location cyberspace Hi, Can't get zonealarm to work under windows 8.1. Can anyone pls recommend me a free firewall that's easy to use? Thanks
27 Oct 2013 at 12:57 #2 Kosmiche Kosmiche Permabanned Joined 3 Oct 2009 Posts 14,033 Location North Wales I used to use Comodo, pretty similar interface to zonealarm so should be easy for you to use.
27 Oct 2013 at 14:19 #3 ShakenNstirred ShakenNstirred Soldato Joined 5 Jun 2003 Posts 8,732 Location sawley/ long eaton If you are using a router then you have a hardware firewall, that with the windows firewall is all you really need Posted from Overclockers.co.uk App for Android
27 Oct 2013 at 16:59 #4 Azuse05 Azuse05 Associate Joined 24 Apr 2009 Posts 1,940 Location Aberdeen, Scotland A lot of firewalls are having issues because of artificial limits in 8.1. You can sort them out with a simple registry tweak.
27 Oct 2013 at 17:10 #5 whitetop whitetop Associate Joined 30 Mar 2013 Posts 438 Location in your garden. Comodo all the way people are moving from paied software to free as it's getting better.
27 Oct 2013 at 17:13 #6 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,898 ShakenNstirred said: If you are using a router then you have a hardware firewall, that with the windows firewall is all you really need Posted from Overclockers.co.uk App for Android Click to expand... This.
27 Oct 2013 at 18:22 #7 Tattooed Tattooed Associate OP Joined 14 Aug 2003 Posts 2,002 Location cyberspace Hi, Thanks for all the replies.
