Firewall Rule Question
1 Aug 2007
Hi all,
Probably a silly question but just checking.
I have some dropped traffic from a source PC which I need to allow through.
I have the destination IP address and the service port is http but the source port is 18825.
We allow outgoing http traffic so I assume I need to allow the source port as http 80 isn't blocked.
Source to Destination on Port 18825 allow
Thanks
Source connections come from a high numbered port and will change all the time, check it again and you'll probably find the source port has incremented.
It would be a rare outgoing connection that used the same port every time.
Without knowing more it'd be hard to advise further, but don't do a block based on source port, it won't end well.
You rarely need to allow outgoing source ports on a firewall, it would be the destination port on outgoing. What service is it for, what application are you trying to pass? Maybe it has an incoming port that needs to be opened.
best thing to do would be to look through your logs on your FW and see why the incoming traffic is being blocked. ie, what current rule is stopping it?
then you'll know what to edit to all the app/service to work.
