The new NOD32 has a firewall as well as an antivirus then? Might be interested in that.
Yeah I can agree with that. If their firewall is anything like their antivirus its a goodun.If the Firewall is half as good as their AV then its gonna be a good seller.
I know what you mean. At home I have a hardware firewall but I still run a software firewall (Sunbelt Kerio) so I can see what is going out and control it.The reason I asked is I have a hardware firewall on the router and just want something that will see ALL outgoing connections to the net.
I also have 2Gb and I'm no where near using that all up but like you say its nice to try and keep programs as efficient as possible to keep the PC as responsive as possible whilst also as best protected as possible.I have Mcafee's 2007 Firewall but its quite a memory hog as it needs the security centre also. I know I shouldnt really complain having 2GB Memory but 'every little helps'![]()
The Comodo one isn't bad either.
Ah OK. Oh and 4 x "so" btw.Well not so much use less and less memory. More that so they are not so bloated with so much rubbish that the end user really doesnt need.
Symantec for example
Edit: How many 'so' did I put in 2 sentences?![]()
