firewire to usb??
11 Mar 2009
Hi there,
I have a firewire usb external dvd drive... is there some way i can use this for devices that doesn't have firewire but has USB?
Is there some sort of attachment that i can get?
any help is much appreciated!!
:confused: Please retype your question more clearly :)
If you mean can you use a usb plug to a firewire mobo connection the answer is NO don`t do it
or is it a dvd drive with both firewire and usb connection
Hi there,
Is your device Firewire? and your motherboard only has USB?
If yes and yes then your stuck. You could get a Firewire PCI card to add a couple of ports to your machine.
