First 2500k OC - Confused/concerned by results
18 Oct 2002
Kent
First off, i used these settings for my OC except i decided to make my first attempt at 4.2ghz. Also there was no XMP1.3 setting for me and my RAM is rated at 1.35V.
To get a quick idea of temps and what not i ran IBT for runs.
What concerns me is that the hottest core reached 71c with a Noctua NH-D14 (albeit with the ultra low noise adapter) and 2 case intake fans and 2 case exhaust fans (top and rear).
What confuses me is the vcore. When i first can coretemp on stock settings it read the VID as something like 1.19v (which seemed low?) but during the test it was changed from between 1.37 and 1.39 when i thought VID was a constant number.
Secondly, i set the vcore in the bios at 1.30v but as you can see from the screenshots both CPU-Z and AXTU are showing a vcore of around 1.2 with occasionally dropping lower.
My questions are basically a) whats going on with my vcore and b) if it was running at only 1.2ish is a 71c temp kinda high?
Thanks
Temps do seem a little high for an NH-D14 @4.2/1.2v.
VID is as far as I know constant based on clock speed and core usage, mine floats between 1.37 and 1.38 under load, occasionally making my offset jump from 1.312v to 1.32v. I wouldn't worry too much about the hot core either, seems to be a common trend on SB, you'll probably find your package temp is around 67c.
In my bios should i set it to Fixed Voltage or Offset Voltage (i think that was the other choice)?
Thanks
p.s Hope you enjoy Trackmania 2 :)
My VID fluctuated between 1.25 v to 1.3611 v even @ idle .
Earlier today Core Temp reported my Frequency as 303.3 X 44 ^^ so probably just not reporting VID correctly as well.
I just ignore it & look @ Core Voltage in CPU-Z.
Its upto you if you want fixed or offset, fixed will leave your vcore at said voltage all the time, offset will set a reduced voltage under speedstep. your offset is -/+ from your VID, its probably the more popular option.
Yeah loving TM2 so far! moved up 20,000 ranked places already :p
