Firstly I have never built a HTPC but have built many standard builds.
I currently have an old Topup TV Freeview Recorder that is on its last legs so thought this would be a good time to build something.
I will probably be using Windows 7 until Windows 10 gets released. The build does not need to be anything special, my TV is currently only 720p. As long as the build can handle 1080p it should be fine.
I will be using the HTPC for:
- Catchup TV
- Recording Freeview
- YouTube
- AirPlaying from iOS Devices
Features Required:
- AirPlay (if this can be done to a Windows machine)
- Fanless Heatsink
- Small HTPC Case
- Dual Tuner Freeview Card
- IR Sensor (will probably use a harmony remote)
I'm guessing Plex is the best software to go with? For CPU I'm guessing i3?
Any help, suggestions and hardware recommendations appreciated!
- Catchup TV
- YouTube
Features Required:
- Fanless Heatsink
- Small HTPC Case
