Hey guys, been messing around with my new C2D rig. Would just like some opinions/advice on my progress so far.
Temps peak at about 66-70 (it fluctuates quite a bit) under maximum stress. (I'm running Orthos and Prime95)
Idle is around 40.
It seems to be stable, although I havent had a chance to let it run for hours and hours.
I'd like to get it up to 3.5Ghz but I'm not sure if I should go any higher with the Vcore? Is it too high as it is? 70 seems a little on the hot side I guess.
Cheers
Idle is around 40.
Cheers
