- 18 Nov 2011
Hey everybody. I thought as i've had my Gaming PC for ages now and have an unlocked I7 2600K processor I thought it would be kinda stupid not to at least try overclocking it. Now this is the first time I've overclocked something other than a GPU & My phone. So this was my first attempt at overclocking my I7. So here are my results...Running on a vantage A.L.C liquid cooler
Overclocked to----> 4.4Ghz
Voltage using Prime 95 (Full load)----->1.248 Volts average
What i'm Using:
Asrock Fatal1ty Z68
Intel I7 2600K
Vantage A.L.C liquid cooler
Basically what i'm asking is whether i've done it right or not does it look normal?
I have done quite a bit of research about overclocking over the past couple of days so I Have a little more understanding now.
(I Was running Prime95 while taking screenshots!)
Temps:
http://img4.imageshack.us/img4/9792/tempsl.png
Volts:
http://img841.imageshack.us/img841/9168/volts.png
Bios:
http://img268.imageshack.us/img268/3092/201303020008161.jpg
http://img837.imageshack.us/img837/3092/201303020008161.jpg
http://img201.imageshack.us/img201/2761/201303020008481.jpg
Are the volts ok?
Are the temps ok?
Anything you can recommend?
And if i'm running at more-a less
at stock voltages have I voided or shortened the Life expectancy of my CPU?
Can I overclock to 4.3- 4.4ghz at stock/auto voltages? Instead of putting manual voltages?
Many thanks for what ever advice you can give!
What i'm Using:
Asrock Fatal1ty Z68
Intel I7 2600K
Temps:
Volts:
Bios:
Are the volts ok?
Are the temps ok?
